SBF Guys: Tips on 302 performance?
Discussion in 'The Hokey Ass Message Board' started by Mike51Merc, Jan 10, 2013.
  1. falcongeorge
    falcongeorge
    from BC
    There. Fixed that for you.
  2. mustang6147
    mustang6147
    from Kent, Ohio
    GT40 heads are in the Explorer SUV's with 302 and 4x4 option. You may find them in a boneyard.
  3. George
    George
    From what I can see, the early heads with dish pistons increases C/R from 8.0 to 8.3. With flat tops it goes to 9.9 a little high for today's gas.
  4. Heo2
    Heo2
    It all depends on what dynamic c/r you get. Static c/r dont tell you
    much the wilder the cam the lower the dynamic c/r gets
    you need atleast that if you want the engine to
    be near a roadracing engine
    Back in the dark ages when you couldent buy any
    fsb heads i used 65 289 heads with 1.90/1.60 milodon
    superflo valves, ported, screw in studs, polished cc ed chambers,
    milled 1 mm, new guides.( Can you do it yoursef or have to farm it out?
    farming out will cost you )TRW flat tops, cams around 260-265 degres
    at 050 500-510 lift shelby , performer rpm,weiand stealt,intakes
    650-780 carb a good combination wery strong in midrange and like
    to rpm shifted at 6500- 7500
    but today i would buy heads
  5. Deuces
    Deuces
    Aman!!!..:)
