SBF transmission swap
Discussion in 'The Hokey Ass Message Board' started by Peter Mc Mahon, Jul 9, 2010.
  1. Peter Mc Mahon
    Peter Mc Mahon
    from Ontario
    Hi guys. I have a 78' [for now] 302 for my truck. I want to put in a AOD trans. but are there issues with the balance? Which ring gear should I use? Thanks for any help as always. Peter
  2. Ole don
    Ole don
    Screw it together with the flywheel that fits the trans. It will work fine
  3. MercMan1951
    MercMan1951
    I think you have to match the balancer to the flywheel. You can't mix an AOD (newer)flywheel with a '78 balancer - sometime around '82, they switched to a 50oz-weighted balancer and that has to match the flywheel otherwise you'll have a horrible vibration. If you poke around a Mustang forum, I'm sure you'll find all the info you need to complete the swap.
    EDIT: Here, I found some info I had that is very complete:
    http://www.mustangsandmore.com/ubb/DanJonesC4AODswap.html
  4. Hnstray
    Hnstray
    from Quincy, IL
    I did this swap on an earlier 289. An issue arises first with the number of teeth on the driveplate (flywheel).......the early ones are 157 tooth and 28 ounce imbalance. The driveplate used with AOD's, at least in my case was 164 tooth. The stock AOD flywheel (164 tooth) was also 50 ounce imbalance. My solution was to buy (from Summit) a 164 tooth, 28 ounce driveplate AND the correct 'seperator plate' that goes between the trans case and block. It is needed because the starter opening is in a different location on 164 tooth flywheel/tranny cases.
    Ray
  5. Peter Mc Mahon
    Peter Mc Mahon
    from Ontario
    Hmmmmmm............
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    Also checkout this website: www.clickclickracing.com this is all about AOD transmissions,Silverfox the moderator can probably hook you up or direct you to a source.
