Projects SBF VALVE COVER GASKETS
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Jun 5, 2023.
  1. seb fontana
    seb fontana
    from ct
    30 year old rubber gaskets starting to weep some, tightening did no good so bought new Fel Pro today, rubber steel reinforced. Look quality. $49 and change. I go see the Dr. about my Sciatic issues tomorrow.
  2. 57JoeFoMoPar
    57JoeFoMoPar
    $49 for valve cover gaskets?! Damn, did you seal them with some Grey Poupon?
    I'm all about the cheap cork, which I've always found seals best.
    da34guy and olscrounger like this.
  3. Yikes!!! Where did you buy them? And yes, I’ll have some Grey Poupon on my sandwich.
    I just looked on The Rock and the premium ones are from $25 to $33. Ugh!! I can see $49 locally. Great, I’ve got one starting to leak on my F-150. Thanks for the reminder.
    mad mikey likes this.
  4. seb fontana
    seb fontana
    from ct
    Auto-Zone around the corner and a bit from me. I have some Cork still packaged that are probably 50 years old. Didn't want to trust them.. I'll take standard yellow please.
    mad mikey and SS327 like this.
  5. 327Eric
    327Eric
    Those 50 year old gaskets will work just fine on my 60 year old perennially over torqued valve covers. Amazon offers cheap rubber gaskets, But I recommend leaving them in China, and buying the better Chinese gaskets elswhere
    seb fontana likes this.
  6. brando1956
    brando1956
    Replaced valve cover gaskets and oil pan gasket on the SBC in the OT plastic sports car I just bought. They are The ****. Steel inserts make install easy and prevent over-torquing. Went from leaking so bad smoke rolled out from under the hood when running to leak free. Not a drop on my garage floor now. Paid $27 for valve covers and $37 for oil pan at Rock Auto. Pan gasket also came with some slick plastic retainers that hold the gasket to the pan, makes in car replacement a breeze. None of this **** of trying to line up and seal corners on the old 4-piece set. I sold Victor for years but I think FelPro has them beat on these.
    mad mikey, seb fontana and loudbang like this.
  7. deathrowdave
    deathrowdave
    from NKy
    SBF with the steel must be seen , they are tough stuff , for sure a life time gasket . I have sets salvaged from engine builds hangin in the garage . These are not the tin insert generic made stuff .
    seb fontana and egads like this.
  8. TA DAD
    TA DAD
    from NC
    Sounds about right for blue Fel Pros.
  9. lippy
    lippy
    from Ks
    Small plastic bottle of sprite and no gasket......$2.48 here.:(
  10. uncle buck
    uncle buck
    #VS13264T are the gaskets in question. Yes they may be more expensive, but they are the best you will find in my opinion
  11. milwscruffy
    milwscruffy
    $25.20 on Amazon and free shipping.
  12. seb fontana
    seb fontana
    from ct
    I shoulda checked; next time..
    milwscruffy likes this.
  13. mad mikey
    mad mikey
    I use Cometic gaskets, not cheap, but they work and are re-usable.
  14. jimmy six
    jimmy six
    Permatex #2 gasket to cover. Let sit about an hour with weight on top. If you don’t look inside Permatex both sides.
  15. Malpass
    Malpass
    Those rubber/steel core gaskets are the truth! I’ve had a set on the 302 in my Fairlane since I’ve had the car which is going on 13 years now. They’ve never leaked once!
    Deuces likes this.
