1952-59 Ford scallops
Discussion in 'Off Topic Hot Rods & Customs' started by mr. h, Jul 3, 2012.
  1. mr. h
    mr. h
    hey gang, im getting ready to think about paint. i really really like scallops. does anyone have any pics of 52, 53, 54 with scallops. it would be greatly appreciated. Im just trying to see what i like.
  2. Retro Jim
    Retro Jim
    I am also thinking about using them on my 55 Ford !
    Jim
  3. bigshawn
    bigshawn
    Scallops look great . Your headed in right direction.
  4. mr. h
    mr. h
    well i am finally decided on paint and a painter. a good friend of mine has a body shop (he is kc, from fast n loud) he is going to let me as much work as i want to save on cost. we are going to blast it and epoxy primer it. then we found a metalic color very close to the color it is now (im going glossy) and then a darker shade of the same color on the top in heavy flake. then scallops top and bottom. not going to be able to start until september and i shall start a thread when i do start.
  5. Ole don
    Ole don
    The old time scallops look best to me, there are no square corners. I taped string to the center of the hood, over the fenders, and down to the bottom of the body near the rear wheel opening. That is the top line. I used pencil to mark the tip of each scallop on that line, and a margerine lid to make all the inside curves the same. More string to make all the lines straight, stand back to see if it looks good from a distance. 1/4 inch tape to get started, then 3/4 tape, masking paper, sand and shoot.
  6. Custom_Crestline
    Custom_Crestline
    I always side with the "less-is-more" mindset with scallops, unless you're doing freeway scallops, then that is a different story!
  7. Used Up Junk
    Used Up Junk
    from Merced, CA
    My Girl's '54. We both hate the color but the layout is pretty good. I just wish they hadn't painted the whole rocker purple. We just lowered the car three more inches since this picture and because of that light color down low it still really does not look that low.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    I actually like the color combo,I would consider having the scallops pin striped with a much lighter color to make them "pop" or turn the rocker into a thinner scallop like the ones above it.
  9. mr. h
    mr. h
    custom crestline, that is exactly what i am looking for. thank you.
  10. Retro Jim
    Retro Jim
    That is a SHARP looking 54 !
    Jim
  11. Custom_Crestline
    Custom_Crestline
    No problem! You'll do the car right
    Here are some weird free-way scallops
