Technical SCAT crank for 21-stud
Discussion in 'Traditional Hot Rods' started by biggles, Sep 14, 2019.
  1. biggles
    biggles
    from England
    Is there any experience here of fitting a 4" **** crank to a 21-stud block?
  2. Is that a babbit bearing engine? If so you might need the machinist to fit the crank,and make any adjustments for clearance.Not a lot of guys in America doing that work...the UK may be the same way.You would be better off with a later insert block,but im sure in the UK you work with what you have.
