SCAT Engine Rotating Assemblies 1-94605BI
Discussion in 'The Hokey Ass Message Board' started by True till Death, Aug 19, 2010.
  1. True till Death
    True till Death
    SCAT Engine Rotating Assemblies 1-94605BI Rotating Assemblies from SCAT are fully balanced and include rings, rod / main bearings, SCAT crank, Ross pistons.
    SCAT good stuff or pass?
    1-94605BI setup is:
    <TABLE border=0 summary=""><TBODY><TR><TD class=body>Cubic In. |</TD><TD class=body>Piston Bore |</TD><TD class=body>Stroke |</TD><TD class=body></TD></TR></TBODY></TABLE>
    <TABLE border=0 summary=""><TBODY><TR><TD class=body> 286</TD><TD class=body> 3-5/16"</TD><TD class=body> 4.125"</TD><TD class=body></TD></TR></TBODY></TABLE>
  2. doctorZ
    doctorZ
    we use 'em in our racing engine (3-3/8" x 4-1/4") and sell the complete kits. we have had nothing but good luck with them.
  3. True till Death
    True till Death
    Thanks for the info doctorz, are you running a blown setup on the race engines? I know on flatheads 286 is a grey area for running a blower or going n/a. As far as filling the cylanders with air.
  4. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I have had several engines built using the 4 inch X 3 5/16 Scat kit and they have worked great.
  5. Scat builds quality parts. We're using a scat crank in a blown big block we're putting together. We went rhough 4 cranks from another well respected manufacturer never got one that wasn't either knicked or that would mic out correctly. Contacted Scat and they sent us a perfect crank first time out.
  6. SCAT is very high quality stuff and Tom Lieb is a Hot Rodder throguh and through
  7. lippy
    lippy
    from Ks
    Ran a scat crank and rods in a 408 stroker sbf 351 W. Went 7.90's all day long on 25% nitro injected. Nothing wrong with scat stuff. Sold the engine and the rotating assy went in another dragrace engine and is still going. Lippy
  8. #### Scat = Good. Poor decisions made after the engines built = Bad >>>>.
  9. doctorZ
    doctorZ
    it's an original 59AB block, bored/ fully sleeved/ ported/ polished/ relieved with high dome pistons. we're running fuel and about 20 lbs. of boost. at least that's what it was until we killed block on monday in bonneville ...
