Technical Scattershield with block plates?
Discussion in 'The Hokey Ass Message Board' started by Dave G in Gansevoort, Sep 14, 2024.
  1. Dave G in Gansevoort
    from Upstate NY
    ****tershields were required on the dirt cars but we didn't need a block plate. The bellhousing was the same depth as a stock GM cast bellhousing, so no issues with pilot bearings and spline engagement. The bellhousing I have in the Whatever project is a Speedway product, again with no block plate, so no issues with pilot bearings and spline engagement either.
    My question is, are bellhousings made for use with block plates slightly less depth to compensate for the plates thickness? And how thick are the block plates? I've done my idiot best to search for the answer, but remember that I am computer illiterate. Thanks for the information...
  2. squirrel
    I guess I could go measure...mine is off right now....
    Dave G in Gansevoort likes this.
  3. Fordors
    Fordors
    My Lakewood block plate is 10ga., .132.
  4. squirrel
    6-5/16" is the (close) measurement of bellhousing depth, block to transmission surface. This I measured on an old bellhousing, and my almost new Lakewood approved ****tershield.
    The Lakewood block plate is 0.125" thick.
  5. Dave G in Gansevoort
    from Upstate NY
    Thanks guys. Just what I needed to know. Now to do some redesign of the firewall in the Whatever project!
  6. patsurf
    patsurf
    an 1/8 made you have to redesign??
  7. Dave G in Gansevoort
    from Upstate NY
    No, BUT it means what I want to do is viable. As you know, I way overbuilt the firewall with 2, 1/4-inch aluminum plates sandwiching the fibergl*** firewall of the body. The slight change I'm thinking about will allow me to use either a manual transmission and an SFI rated bellhousing, or a Powerglide, again with an SFI rated bellhousing without affecting anything else. More on that coming up in the Whatever project thread, when I get a round tuit...
