Scavenger pumps??? Who makes them
Discussion in 'The Hokey Ass Message Board' started by HotRodDrummer, Nov 15, 2006.
  1. HotRodDrummer
    HotRodDrummer
    I've googled and searched here with no luck, unless I was building a boat or an old bike....
    who makes a 12v scavenger pump for cars? I don't know the intended use, I was just asked to try and find out who makes them and how available they are.
    any thoughts? DO they make dif. capacities?
    Any info on how they work?
    thanks
  2. 53sled
    53sled
    from KCMO
    Do you want to evacuate the crankcase? to keep rings seated/ lower the blowby?
  3. HotRodDrummer
    HotRodDrummer
    Return oil from turbo to crankcase...
    so I am told, this is for a friend..just tring to get some info.
  4. Most turbo,s I,ve seen are fed oil pressure from a gallery then just have a dump back into the pan.....
  5. 53sled
    53sled
    from KCMO
    They usually just drain with gravity, pressure is applied to the other end so it's not a problem until you shut er down.
  6. HotRodDrummer
    HotRodDrummer
    The turbo is at the back of the car well away from the pan.
  7. HotRodDrummer
    HotRodDrummer
    so.... who makes them.....
    I'm sure nascar uses something for thier dry sump set ups.....
    Anyone??
  8. dehudso
    dehudso
  9. Flat Ernie
    Flat Ernie
    Tech Editor
    Road racers & NASCAR would be my bets if I had to look, but I've got no experience with them. Have seen 'em for differentials to run the gear oil to a cooler & back, but wouldn't even know where to begin looking....
    ...I'm no help, I guess I'll leave now. ;)
    EDIT: Need to type quicker, looks like dehudso has a lead!
  10. HotRodDrummer
    HotRodDrummer
