Schiefer Flywheel-Info/Help Needed
Discussion in 'The Hokey Ass Message Board' started by Dick Steinkamp, Aug 16, 2011.
  1. Dick Steinkamp
    Dick Steinkamp
    I'm building an early 3.5 Rover aluminum V8 and T5 for an MGB. The Rover is the same as the 215 Buick and similar to the 215 Olds
    I recently bought a 215 Olds for parts and was surprised to find the flywheel on it is a Schiefer aluminum one...
    It's drilled for a Long style clutch cover...
    Mine appears to have never have had a steel or bonze insert and looks like it has been run on just the aluminum surface which is somewhat grooved due to this.
    What is the story on these? Can I surface it and run it as is? Is there some sort of coating that was or should be applied (metal spray/flame spray)?
    Here's the motor it would go on mocked up with the T5...
    Here it is running (with an automatic flex plate)...
    http://www.youtube.com/watch?v=49KZv2CIg5M
