school me on 32 pedals
Discussion in 'The Hokey Ass Message Board' started by wideglide74, Apr 24, 2004.
  1. I have two sets of 32 pedals. This is the first set and as far as I can tell out of a car as it bolts into my K member and appears the same as the set used in the B/T book.
  2. Again... I cut the lid out today that someone else added...
  3. This is the second set. The pedal arms are shorter, the clutch, brake arms are located diffrently, the mounting box is diffrent than the other set and it does not fit correctly in my car K member.
  4. again...
  5. Today I took both sets apart and combined the proper mounting can with the shorter pedals and it seems to be the ticket for my AV8 as the clutch linkage connects perfectly to the 39 gearbox and the pedals clear the bellhousing better. My question is what application are the two diffrent sets...
  6. dondanno
    dondanno
    wg if you plan on juice brakes here is something I did so the mast cyl. does not hang below the frame. For me it just does not look good and if you have a low car its the first thing to get hit. It bolts in right behind the pedal ***embly and stock 32 xmember. I cant find a pic right now of it in the frame but I will get one if you would like.Any way check this out...Danny
  7. Don't know if this will help, but it's a pic of the pedal setup from the underside of a somewhat unmolested 33 three window.
    Unmolested translating to an old hot rod, built in the early 60's or so.
