Technical School me on a Banjo rear end....
Discussion in 'Traditional Hot Rods' started by craigibc, Feb 17, 2015.
  1. craigibc
    craigibc
    I have done some searching and not able to find much information. Can you school me on the Banjo rear end?
    I eventually want to use the axle tubes on a V8 quickchange.
    1. What years am I looking for?
    2. Do you know what the length of the axle tubes should be both left and right? This is going in a hot rod and I have heard I might need two axle tubes from one side.
    3. What is the measurement of the banjo with a tape measure? cir***ference?
    Heading to the Big 3 here in San Diego this weekend and I want to bring one home with me.
    Craig
  2. alchemy
    alchemy
    Get a 39-40 Ford rear axle and you should be fine for any hot rod 40 and under. Same axles both sides. If you are building a 41-48, get a rearend from one of those (a little wider).
  3. ydopen
    ydopen
    The 37-41 axle housings are 27 1/2" long. The 42-48 are about 1" longer so a 2" longer rear end. Which one you want depends on the what you are building. AV8's usually use the shorter tubes. Quick changes are available for any early Ford banjo rear end 28-48.
    John
  4. ydopen
    ydopen
    Alchemy got it,I typed too slow.
    John
  5. craigibc
    craigibc
    thanks for helping me out!
  6. Ken Smith
    Ken Smith
    Alliance Vendor
    A quick change will require a 6 spline pinion gear. If you can find a rear end with a good 6 spline ring and pinion, you will be able use it in the quick change.
    28-31 A housings won't fit a V8 QC center, so don't get one of those.
  7. craigibc
    craigibc
    Anyway to tell from the other case the year or if it is a 6 spline? Anything on the outside of the case that let me know what the ring and pinion is? Or do I need to crack the case?
  8. Torchie
    Torchie
    You might want to check in with the Banjo rear end social group. Lots of great info there as well as links to I'ding what is what.
    Torchie.
  9. fatkoop
    fatkoop
    If you're planning to keep the stock keyed axles, look for housings with the best bearing surfaces you can find. Gear ratios are stamped on the rib on the bottom side of the center section, like 37-9 (4:11). Other than that, there are several differences in spring and shock mounting, look for info on banjo rears before choosing what you need.
  10. Buck Mc Kinney
    Buck Mc Kinney
    Where can I get a QC to put in a Model A ??? Thx ... buck03021@frontier.com
  11. craigibc
    craigibc
    I found a great article on the banjo group and I am going to take that with me tomorrow. Thanks for the tip.
  12. 19Fordy
    19Fordy
    Well, depending on how deep your pockets are you can start here
    with Speedway.
    http://www.ebay.com/itm/New-Winters-Championship-56-Quick-Change-Rear-End-Dual-Bolt-Pattern-Plain-/261752751272?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cf1ae04a8&vxp=mtr
    QC's are big money, as you probably already know.
    http://www.hotrodworks.com/parts-list.pdf
    Here's a list of vendors for Franklin quick change rear ends.
    http://www.franklandracing.com/dealers.aspx
  13. alchemy
    alchemy
  14. jseery
    jseery
    from Wichita KS
