school me on dzus buttons!!!!!!!!!
Discussion in 'The Hokey Ass Message Board' started by The Wolf, Jun 14, 2006.
  1. The Wolf
    The Wolf
    from OAKLAND CA
    who's used the speedway ones, and do they come complete with all the hardware?:confused:
  2. revkev6
    revkev6
    from ma
    never used the speedway ones, always got them from my local race supplier (local being 60 miles away) they are pretty much a standard item though. buy a bunch of weld on tabs, springs, rivets and dzus "****ons". weld on the tab but don't put the spring on til after you paint. makes for a cleaner install. one suggestion I have is to buy the screwdriver to install them. they fit better and will help keep you from slipping and scratching your paint.
  3. GamblinAJ
    GamblinAJ
    from Corona Ca
    I aswell never delt with speedway, but most race suppliers sell them in all kinds of ways, ****ons and tab, ****ons, tabs. Call Kaeding performance in Campbell California its near you..1 800 KAEDING
  4. Do some research. They come in different lengths, diameters, styles. etc. I used flat heads for dragsters. I made a tool to make the countersink in the panels. I haven't bought any for years but they were always pricey. You might try the Ch***is Shop that's in Michigan. They stock an ***ortment of this stuff.
  5. Some pics of a home-made tool.
    The angle in the 1" aluminum piece is done with an 87 degree countersink.
    3/8" bolt and nut pulls a dimple into the sheet metal.
    Use standard bolt and nut, stainless bolt and nut will gall and creating the dimple will be difficult.
    Works better than the hammer driven commercial dimplers because you can do it with hood etc. on the car if necessary and no backup for the anvil is required plus you can easily duplicate dimple depth in multiple installations.
    Quick and easy to build, works with the Dzus style shown or the ****ons without retainer plate.
    Look close and you'll see a dimple on each side of the body gage sheet metal.
    Speedway makes a nice Dzus remove and replace tool, but I use a dime to operate the Dzus ****ons.
    Works well and doesn't slip.
  6. sodbuster
    sodbuster
    from Kansas
    av8/Mike Bishop told me about this place a couple of years back........They have a great catalog and you will find Dzus fasteners in all sizes.
    http://www.aircraftspruce.com/
  7. dana barlow
    dana barlow
    from Miami Fla.
    There a lot of sizes and you need the rite one,so look at there cats.
    There are times that you'll not have one fit just right,they are adjustible with in a small amount,by bending or spacing the "S" wire,after a short time you get the feel for how snug they should be. If you can not take it apart with a dime=it to loaded,if you can push your fingger on it and open it's to EZ.
    The Bat
    Miami Fl.
  8. Blownolds
    Blownolds
    from So Cal
    I know that Full Bore Products offers/offered Dzus's with allen heads. And I know I have seen Dzus's with round heads and flat heads, in stainless and aluminum. They are not all the exact same!
  9. Da Tinman
    Da Tinman
    If ya need tabs PM me, I sell 50 lightweight tabs for $35, plus S/H.. Got a few thousand in stock, I'll get spring prices in the AM.
  10. Clark
    Clark
    When did they first come availble? I haven't used them cause they don't look right on a car from the 40's or 50's. Where they availble back then? Used by hot rodders?
    Clark
  11. mazdaslam
    mazdaslam
    Try here:www.dfcis.com/history.html
  12. Clark
    Clark
    I guess they were around back then.
    Clark
  13. Roothawg
    Roothawg
    They were used on many aircraft in the early days. They still use em on the aircraft I work on.....
    I always shout this from the rooftops....but anyone that builds hot rods needs the Standard Aircraft Handbook. You can buy it from any book store or Amazon. It will answer 99% of hardware questions.
  14. curbspeed
    curbspeed
    Clark, I suppose your now going to start looking for genuine 1932 Dzuz fasteners to keep your stuff traditional! Ha! Anyone have any first run Dzuz fasteners from the early years and do they look the same?
  15. Radshit
    Radshit
  16. DrJ
    DrJ
    If you're a terminal scavanger, the battery cover, behind the seats, on every MGB is held down with 5 of them. :cool:
  17. IF you are going to use them on external panels, the flush mount (countersunk) look much better IMO. Springs are avail. in 2 different lengths If you use 1" springs with 1" self ejecting plates and align all the body plates, the spring rivet heads hit the body plate rivet tails, as they are ALL in a line. I use the longer springs on the style with plates, they let the rivets get away from each other. BTW, the long springs are also easier to adjust if you have a reach problem with the ****ons. They have a VERY limited grip range for any given length ****on.
    It is possible to get a flush mount Dzus ****on without the rivet plate. If you shop around, you will find flush ****ons with a reduced shank under the head. These are mostly used on aircraft. I made a tool a long time ago to swedge the sheetmetal shut around the shank after the ****on is installed in the body panel. This will lock the ****on in place without any pesky rivets or plates. Of course, they don't pop out, but it hasn't been a problem.
  18. Shaggy
    Shaggy
    from Sultan, WA
    I dont mean to dredge up old threads, but i was flipping through dec 61 car craft or rod and custom, dont remember which, but it had an artical on them
