school me on making big holes in sheet
Discussion in 'The Hokey Ass Message Board' started by ironandsteele, Feb 18, 2013.
  1. ironandsteele
    ironandsteele
    I'm wanting to put some 2" holes in some sheet metal. I have a punch set (hand/ratchet type) that cuts really clean holes, but what I'm wanting is that slightly indented or chamfered hole, as I think it would look cleaner.
    My question is- is this a different type of die or cutter that I need to buy that makes the holes come out that way, or is this a process that is done after the hole is cut with an entirely different tool?
    Any input would be great. Pics always help too if you have any...
    Thanks!
  2. Window Licker
    Window Licker
    Sounds like your looking for a dimple die set
  3. saltflats
    saltflats
    from Missouri
    I think that is where the dipple dies come in.
  4. Hackman
    Hackman
    from Butte, MT
    You could have a local machine shop make you a dimple die for your hole size pretty reasonable. I have made many of them in no time on the ol lathe.
    Good luck
  5. black 62
    black 62
    from arkansas
    dimple dies---for one time use i would make one with a hole saw,a 2x4 , and a socket
  6. 66tintop
    66tintop
    from Canada
    Allstar racing sells punch flare tools , good quality, at reasonable prices, any Motor State dealer can order btw I have a set of 4 , they are good. Under$100.00 each size
  7. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  8. ironandsteele
    ironandsteele
    Awesome. That's what I needed to know. Thank you guys!
  9. strike a poser
    strike a poser
    from Salinas,CA
    Search for the homemade tools thread. There was a post today covering exactly what you're asking for. Using a homemade die to use on the hole punch set you already have. Good info.
  10. Grudge
    Grudge
    They are super satisfying and easy if you have the right tool. The kit with punches, dies and an air-over-hydraulic ram is ~$1,000...which is why I borrowed one :D
