school me on nailheads
Discussion in 'The Hokey Ass Message Board' started by triumphtony, Feb 29, 2008.
  1. triumphtony
    triumphtony
    I am thinking about putting a nailhead (364) in my truck. wantinig to know can you get parts still rebiuld kit,starter,waterpump dressup parts **** like that (prety cheap and eazy) are they reliable? do they get gas mileage? can you put a 700r4 trany on them? and so on. any help with this would be cool
    Thanks
    T
  2. hotrod1940
    hotrod1940
    All of the above, except the mileage part.
  3. Google is your best friend to get basic information that a lot of us don't have at our fingertips. There is at least one Buick bulletin board, One of the magazines did an in-depth series a couple years ago. It should pop up under a nailhead search along with a lot of suppliers. Search eBay motors under 364 Buick, or 401 Buick or Buick nailhead. Kanters out in Jersey has engines parts a**** others.
    I'm sorry, but doing your homework isn't asking us to school you.
    Charlie
  4. donut29
    donut29
    from canton MI
    everything you need to rebuild you can get from TA , egge and some other places do a seach on here or go to V8buick.com lots of good info on there I can tell you it will cost you 3-4k to rebuild a nailhead right
    good luck
    Tom
  5. triumphtony
    triumphtony
    I am not tring to get you to do my home work .I tried google and got casting numbers and that does not answer any of my? and i got links to ebay and I do not use that so no help there and info from someone who has one in there rod would know more than a web site and where they got a good deal or not.
  6. 51-322special
    51-322special
    go to www.buicks.net. register and they will more than skool you on nailheads . give it a try. beats doing home work..; ) as for your questions..yes yes yes and no..those dogs burn fuel like any other v8. egge,kanter and many other offer kits plus service to rebuild yer old pumps wich they are no longer avaliable new. ebay is a good place to find parts. if you dont use it then yer missing out. beware that it could get a bit pricey on there.
  7. TagMan
    TagMan
    I got a 401 with 2x500cfm AFB's with a healthy cam sitting in a '55 Buick Special. I get about 15 mpg, if I keep my foot out of it.
  8. zman
    zman
    from Garner, NC
    There is plenty of info right here on the HAMB, most of it easily found with the search function. No need to go to the other boards as a lot of the same guys are right here...
    This one should get ya started
    http://www.jalopyjournal.com/forum/showthread.php?t=96479&highlight=nailhead+parts
    yes they are reliable when done correctly. gas mileage is about the same as most v8's from that era. you can put a 700r4 or 200r4 on with an adapter. personally I'm not a big fan of adapters and the st400 or sp400 from 65-66 are great ******'s
  9. panic
    panic
    Hunt around. The last 425 used the switch-pitch TH400.
  10. Candy-Man
    Candy-Man
    Call Carmen at J&C's Parts in N. Tonawanda N.Y. at (716) 693-4090. He is excellent to deal with and a nailhead guru...
  11. hotrod1940
    hotrod1940
    The switch pitch is an SP400
  12. hot rust
    hot rust
    trans adapter---bendtsen transmission center 763-767-4480. have one on the engine in my merc. excellent part!!!!!!
  13. zman
    zman
    from Garner, NC
    The SP400 is a Nailhead bellhousing TH400 with a switch pitch torque converter. The TH400 came from the SP/ST 400's in the Buicks. The internals from the 65-66 are the same, the 64 has a different valve body.
