Technical School me on vacuum wipers!
Discussion in 'The Hokey Ass Message Board' started by Jimv, Jan 3, 2015.
  1. Kerrynzl
    Kerrynzl
  2. Rusty O'Toole
    Rusty O'Toole
    The double decker fuel pumps with vacuum pump for the wipers, were offered on all old cars that came with vacuum wipers. They cure the vacuum problem on hills and on acceleration. Last one I bought was for a 59 Ford, it cost $50 more than a standard fuel pump.
    Rebuilt wiper motors are also available. Rambler, Cadillac, Buick and Packard use vacuum wipers up into the fifties and sixties, Cadillac Buick and Packard had auxiliary vacuum pumps built into the motors. They must have thought well of vacuum wipers to go to the trouble, since electric wiper motors had been available from the forties.
  3. oldcarguygazok
    oldcarguygazok
    from AUSTRALIA.
    Had many 'run ins' with vac wipers,my solution is to lube the motor,only if it's dry and yes,use lithium grease.I then run the air hose from the motor to the inlet manifold,use a brass tap and you can control the air intake,works great !
  4. brad2v
    brad2v
    During the rebuild of my '57 Pontiac, I discovered the wiper motor was seized. After much thought, and reading through this thread, I decided a $600 electric conversion was not for me, partly due to a great lack of $600, and partly due to the fact that I'm not likely to drive it to Seattle in December. I could probably rummage the boneyard for a suitable electric unit to swap, and I may, if I decide the vac wipers are completely useless, but I've had 'em in the past and they were ok. Here are the results of my rebuild. Step one was disassembly, then a cleaning of all the pieces, of which there are very few. Basically, it consists of a chamber, in which a paddle sweeps back and forth to provide the motion, a top cover 'valve body', that directs the vacuum, and a small cover that slides on the top of the valve body activated by the cable from the switch. pontiac0215 006_opt.jpg pontiac0215 007_opt.jpg
  5. brad2v
    brad2v
    The chamber was in great condition, and a beautiful aluminum casting, once I had all the paint off. The top valve body piece is some variety of pot metal. The aluminum piece was begging to be polished, so I couldn't resist. I cleaned up all the pieces, and painted the two sheetmetal cover parts, and reassembled it with white lithium grease. I made the gaskets using the ball pean hammer method, pressing the gasket material to the part, and knocking the excess away with the hammer. I used a leather hole-punch for the round holes in the gaskets, and referenced the old gaskets for the inner cutouts. pontiac0215 010_opt.jpg pontiac0215 046_opt.jpg pontiac0215 058_opt.jpg
  6. brad2v
    brad2v
    The screws holding this thing together by the way, are super tiny, with a goofy flat on two sides, raised head, that I could only figure to remove and install with a needle nose pliers. pontiac0215 059_opt.jpg
  7. brad2v
    brad2v
    Now, to my questions for those of you who have been in one of these before. In the front part of the chamber, is a separate cast in housing with a little valve arrangement. On the bottom part of that is an inlet or outlet port, and a filter ahead of it. Question one, this filter is a felt sorta material, and I just gave it a bath in hot water and re-installed it. Should I find a replacement?
    Question two, it seems apparent to me the vacuum hose from the engine would go to the tube on the upper casting, but the lower chamber has the aforementioned nipple on the bottom. Is that an outlet, as in, no hose? My brain tells me yes, but my brain has lead me astray in the past :rolleyes:. pontiac0215 051_opt.jpg pontiac0215 013_opt.jpg
  8. brad2v
    brad2v
  9. Rusty O'Toole
    Rusty O'Toole
    For oiling your wiper motor try vacuum oil or air tool oil.
  10. 56premiere
    56premiere
    Those screws are a pain but I use a piece of steel tube squished to an oval in a cordless drill.
    brad2v likes this.
  11. Ok question, on my 56 buick wagon.the vacuum hose is on the bottom of the wiper motor, how do I get oil or brake fluid up it to it? While I had the top of the dash off I cleaned and used white grease on the cables and the other parts.Thanks Bruce.
  12. Steves46
    Steves46
    from Florida
    Besides lubricating the motor, squirt some white lithium grease to all the pivot points on the linkage. I did this with mine and it made a world of difference.
  13. wvenfield
    wvenfield
    That might be the best looking barely acceptable piece of equipment I've ever saw.
  14. brad2v
    brad2v
    Clever, guess that's why I never thought of it. Filed in the ol' noodle for next time.
  15. My Rambler has vacuum wipers. Best thing about them is the infinite speed adjustment. You can set them to run reeeeaaallll sllloooooowww.
  16. Vaseline works great on vacuum wiper motors. Take it apart, dip the paddle in Vaseline, and reassemble.
