Technical Schroeder steering with a Vega box?
Discussion in 'The Hokey Ass Message Board' started by Txkahuna, May 22, 2014.
  1. Txkahuna
    Txkahuna
    from Texas
    Has anyone ever used a Chevy Vega steering box for a Schroeder style steering setup?
    hotrod_daddy@att.net
  2. That would make a neat tech thread.
  3. jaw22w
    jaw22w
    from Indiana
    You just have to mount the pitman arm pointing up.
  4. Txkahuna
    Txkahuna
    from Texas
    Hey, Jaw22!
    Why is that?
  5. HammerDown
    HammerDown
    It's pretty important unless you're real good at steering boats...
  6. Txkahuna
    Txkahuna
    from Texas
    Never seen one setup that way!
  7. jaw22w
    jaw22w
    from Indiana
    If you install the pitman arm pointing down, it will go left when you turn right with a vega box. A reversed corvair box will install with the arm pointing down. Vega boxes are usually used in a cross steer system.
  8. Txkahuna
    Txkahuna
    from Texas
  9. A Boner
    A Boner
    Reverse the Vega box like they do with a Corvair box, then the pitman arm will be pointing down.
  10. Txkahuna
    Txkahuna
    from Texas
    I have never reversed a Vega box! Does anyone have any pic's showing how?
  11. butch27
    butch27
    Spirit t buckets use the Vega and the pitman points UP. --Not reversed.
  12. gecko54
    gecko54
    from Sumner, WA
    August issue of Rod & Custom shows a Vegas box being used, not though the cowl but though the frame. Pitman arm is pointing up.
  13. If you're wanting cowl steering use a 60's mopar box.
  14. A Boner
    A Boner
    Basically the same as on a Corvair, except having to turn off the big hex, to make room for a u-joint to connect the column. After turning off the hex, you have to drill a couple holes for a spanner wrench to tighten the cover/cap.
  15. mgermca
    mgermca
