Technical Schroeder Steering
Discussion in 'Traditional Hot Rods' started by Shoovel, May 9, 2023.
  1. Ziggster
    Ziggster
    Can’t say for sure as I’ve never built anything from scratch, but the speedster I’m modelling mine after (Richard Scaldwell’s GN JAP) seems to be doing just fine after more than 10 yrs on the road and track. No friction shocks either on his.
    Ned Ludd and 26 T Ford RPU like this.
  2. 26 T Ford RPU
    26 T Ford RPU
    That explains it. cool. JW
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    WOW wooden front axle and frame. Reminds me of Morgan frames and WW I biplane propellers.
  4. Ned Ludd
    Ned Ludd
    The wooden axle is interesting, but Morgans never had wooden frame rails. They had, until very recently, ash body framing which, as people are unfamiliar with this (once common) way of constructing coachwork, is very often misinterpreted as wooden frame rails. Early three-wheelers had small-diameter metal tube frames much along bicycle lines, and most four-wheelers and, I believe, later three-wheelers had steel Z-section rails whose lower, inner flanges bore the wooden floorboards.
    A better example of a wooden frame would be early Franklin:
    rod1 and Ziggster like this.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thanks for the correction/clarification Ned Ludd.
    Ned Ludd likes this.
  6. Dave G in Gansevoort
    from Upstate NY
    And if you look really closely at the front axle, you'll see it's a steel axle with a wooden fairing. I can't imagine it made much of a difference...
  7. Ziggster
    Ziggster
    Looks like the front axle is wood, but it’s steel. I’m guessing that is just some type of decorative “spoiler”, but the frame rails are indeed wood as all GN were up to about 1918 IIRC.
  8. Daniel Dudley
    Daniel Dudley
    Do the simple stuff first. Work your way up. There is a reason they make steering dampers, and they aren't too expensive. Remember that bump steer and wobble are two different issues. Fix one, decide if the other is still a problem. Best practices are great, but sometimes you just want to fix the symptom. It it goes away, is it really a problem?
  9. wstory
    wstory
    Don't have mega years of experience,...or opinion but, death wobble is NOT intrinsic to cowl steering. I chased it after many experiments with everything adjustable and worn, replaced the whole front axle, spindles, spring ***embly, shocks...everything! Resisted the dampener band-aid until that was the only thing left. Dampener finally was a fix and at a small fraction of what I'd already spent. And as mentioned here, many builders automatically include that item on a new build with the more traditional steering systems.
    And bump steer. Don't even go there. If your car is safe and comfortable to drive, go for it. If you're not aware of bump steer, figure you don't got it and enjoy the drive and the cool factor of cowl steering!
  10. 26 T Ford RPU
    26 T Ford RPU
    And that leads into the next topic....Bump Steer. JW
