Projects Scored another Model A
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, May 6, 2026.
  1. wheeltramp brian
    wheeltramp brian
    Browsing the local Facebook and this popped up for sale cheap enough and pretty close so I had some conversations with the owner. I was the first guy to bite 20260506_174105.jpg 20260506_174111.jpg 20260506_174118.jpg 20260506_174130.jpg 20260506_174133.jpg 20260506_174152.jpg 20260506_174212.jpg ,and there was 20 behind me ! Went and checked it out and it hasn't run since 97 but that's fine. It's got a ***le, straightest body I've seen in a long time, and a pretty good interior. Plans for now are to get it up and running and put around and then figure everything else out.
  2. Wowsers!, y’all hit the jackpot, won the lottery that is, struck gold. The interior is in great shape, needs a banger though. Hehe
  3. partsdawg
    partsdawg
    from Minnesota
  4. saltflats
    saltflats
    from Missouri
    Nice looks like a good start to whatever you like.
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Man O Gee I'd Be takin' my time and live in the past.
    Like I did as a little squirt :p
    Good going Good Luck.
    Whatever you do
  6. lothiandon1940
    lothiandon1940
    Nice score. Love a sweet Model A.
  7. Outback
    Outback
    from NE Vic, Oz
    That is a great start to a project, shouldn't take too much to get going!
    Dave Mc, Deutscher, Paul B and 3 others like this.
  8. wicarnut
    wicarnut
    Kool Score ! A great start for any direction you choose
  9. catdad49
    catdad49
    You'll be taking it to church in no time. Early Bird Gets The Worm!
    Outback, Dave Mc, Deutscher and 4 others like this.
  10. rusty1
    rusty1
    i like A bones,...good luck with yours...
  11. Loads of fun with room for p***engers. Like I tell my high schoolers, "Answer opportunity's knock immediately or it goes next door."
  12. Paul B
    Paul B
    IMG_2730.JPG IMG_2737.JPG Picked up a 31Coupe on Tuesday sat in the barn since mid 50ties
  13. chiro
    chiro
    ^^^That coupe looks like it did better than the "barn".
    Andy
  14. wheeltramp brian
    wheeltramp brian
    Was soaking the Pistons in the special mixture of ATF and acetone and still wouldn't budge with a pry bar 20260512_161431.jpg 20260512_161435.jpg 20260512_161446.jpg 20260512_161804.jpg 20260513_082636.jpg on the flywheel through the starter hole. Pulled the head off which came off really easy for once. Number four cylinder has rust in it so I proceeded to clean it up and started smacking the Pistons with a 2x4 to get it moving around which worked out great. Once I got that cylinder down all the way on the stroke I ran a ball hone through it and cleaned it up. Couple valves were stuck so I sprayed them with some penetrating fluid. I put the starter back in and she spins over easily and all the valves seem to be free. Got to head gasket and some ignition parts coming tomorrow. Drain the old oil out and there was a little bit of water which is to be expected I guess from the water in the cylinder. We shall see what happens I'm sure it will run but how much is smokes who knows...
    SS327, Squablow, dwollam and 10 others like this.
  15. Dave Mc
    Dave Mc
    Might have a cracked water jacket, if so, preferably in the head. or maybe just head gasket ? Car looks great, congrats.
    bchctybob likes this.
  16. bchctybob
    bchctybob
    I saw that on Marketplace too, glad it’s in good hands!
    Got that blown Pontiac running yet?
    Outback likes this.
  17. wheeltramp brian
    wheeltramp brian
    Haha no time on the Pontiac. The stock Model A stuff is a little simpler
  18. GZ
    GZ
    from Detroit
    Ya gotta love Model As. Every time I see one, I get a smile. Nice tudor!!!
  19. Outback
    Outback
    from NE Vic, Oz
    My first ride in an old car/Hot Rod was an A tudor with a SBC. Same fella still owns it, I have a real soft spot for them. Looking forward to watching the journey
  20. warhorseracing
    warhorseracing
    from cameron wv
    Before you start it only put in about a quart of Rotella 10W30 and 3 quarts of Kerosene. run it for about 5 minutes at idle. It wont hurt it and it will loosen up the gunk in the oil pan, crank drip tray and valve chamber. Drain that out and refill with Rotella 10W 30 and run it.
    down-the-road and Okie Pete like this.
  21. Okie Pete
    Okie Pete
  22. 29Sleeper
    29Sleeper
    from SoCal
    They're out there. Drove this one home for $9,500. Even had a great car cover and a few hundred $ in spares.
    00a0a_5lUorPcdEgo_0jL0eP_1200x900.jpg 00B0B_8FsYjQinizx_0jL0eP_1200x900.jpg 00C0C_a9g3FmEEcwU_0jL0eP_1200x900.jpg 00H0H_7NgSGMArEUf_0jL0eP_1200x900.jpg 00o0o_9SwGIqXrBSU_0CI0t2_1200x900.jpg
  23. wheeltramp brian
    wheeltramp brian
    Parts came in today. Got the head and block cleaned up and copper coated the copperhead gasket and installed it with a new leakless water pump. Hopefully fire tomorrow but we'll see, the shop is full. 20260514_125404.jpg 20260514_125544.jpg 20260514_131325.jpg
    SS327, Squablow, bchctybob and 7 others like this.
  24. wheeltramp brian
    wheeltramp brian
    Filed the points and set the timing, cleaned the gunk out of the fuel line from the tank to the sediment bowl and replaced 20260515_124817.jpg 20260515_125337.jpg the bowl and filter screen and voila it's alive! Runs really smooth. Just got to pull it outside and hook up the coolant hoses so I can put water in it and change the broken crank pulley and burn all the oil out of the cylinders.
  25. warhorseracing
    warhorseracing
    from cameron wv
    If you have to replace the crank pulley get the harmonic balancer and help save the bearings. Babbitt is hard to find anyone to do it and get it correct anymore. Address is, chrismh157@gmail.com and the cost is $350 U.S. shipped.
    SS327 and bchctybob like this.
  26. bchctybob
    bchctybob
    That’s so cool. Love to see the resurrection of old cars like that….
    Edit: did it spit some interesting stuff outa the exhaust?
    guthriesmith, SS327 and Moriarity like this.
  27. hotrodA
    hotrodA
    Love the “EARL” on the filler cap! :D:cool:
  28. wheeltramp brian
    wheeltramp brian
    Had to pull out the radiator to flush out the garbage and it still wouldn't flow too good so I let it soak overnight in CLR. That did the trick. Put it all back together with some new hoses and the thing runs nice and cool. Changed the trans fluid and rear end which were basically empty and drove it up and down the street. It's got an intake manifold leak which I've got some gaskets coming for and it's making a miss a little bit off idle I believe. The tires are a little bit Square LOL 20260521_163524.jpg
    guthriesmith, SS327, Squablow and 3 others like this.
  29. bchctybob
    bchctybob
    Good week for old Fords. My buddy just did a first drive with his ‘40 2dr sedan too!
    guthriesmith and warhorseracing like this.
  30. Greg Rogers
    Greg Rogers
    How cool! Love it when you can get one going like that.
    guthriesmith likes this.
