Scorpion 1 needs a piston
Discussion in 'The Hokey Ass Message Board' started by dwrfab, May 22, 2011.
  1. dwrfab
    dwrfab
    from Dallas TX.
    Group:
    I over reved the Scorpion 1 at Yellow Belly last week. It put a hole in a piston, so I am looking for a 4" +.040" or .050" over, stock compression Piston and rings. I don't want charity I just need a piston very soon so we can take the car to Bowling Green for Bobby langley to cackle.
    Who knows this may be the last time Bobby gets to do this, one just cant tell.
    Thanks Don Ross
  2. propwash
    propwash
    from Las Vegas
    gee...I guess you're only asking this of people you know, otherwise you'd tell us which engine this is for....
  3. dwrfab
    dwrfab
    from Dallas TX.
    Sorry: yea I knew it was a 392 hemi, I just for got that not every body knows what the Scorpion 1 dragster is.
    Sorry Don Ross
  4. cracker head
    cracker head
  5. AAFD
    AAFD
    from US of A
    Bump for Texas Fuel Legend Bobby Langley
  6. dwrfab
    dwrfab
    from Dallas TX.
    Guys and Girls:
    We need a piston bad can any one help ? It can be a stock 4" up to a .060" over.
    Thanks Don Ross 214-327-7312 cell
  7. publicenemy1925
    publicenemy1925
    from OKC, OK
  8. hotrodladycrusr
    hotrodladycrusr
    Come on folks, someone's gotta have one. One of the main reasons I attend the Hot Rod Reunion in Bowling Green is to see my favorite Texas race team.
  9. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    if i had one youd have it
  10. temper_mental
    temper_mental
    from Texas
  11. 1940 Willys Coupe
    1940 Willys Coupe
    from Texas
    Bump For The Great State of Texas!
  12. Ebbsspeed
    Ebbsspeed
    I have one (stock bore) with no rings, but it's got a 1/8 inch hole drilled from top to bottom close to the edge, right above the piston pin. I used it to check pin height on a motor I was building years ago. So if you want to TIG the hole shut, it's yours. Not sure how you feel about welding on a cast piston, but it might be OK for one cackle.
  13. 1940 Willys Coupe
    1940 Willys Coupe
    from Texas
  14. sodbuster
    sodbuster
    from Kansas
    Have you checked with Poverty Flats? He hauled home a TON of HEMI's a couple of years back outta' KC. And a back up to the top for ya'.
    Chris
    Also, I have only chatted with Dale Wilch @ swapmeets, but you might check with him.
    http://www.dalewilch.com/
  15. Dont think we got any stockers... only domed and more hopped up race stuff.... ill PM ya if i can get ahold of one today...
    TH
  16. AAFD
    AAFD
    from US of A
  17. hotroddon
    hotroddon
  18. sodbuster
    sodbuster
    from Kansas
    BTTT....
    Sent from my iPhone using TJJ.
  19. slayer
    slayer
    I have 8 stock pistons from a 392, but i dont know if even one is any good. I bead blasted them last yaer,only to find they pitted from sitting around for years. Here is a picture of the best two.
  20. slayer
    slayer
    I just noticed you siad .40 or .60 over. These are standard bore. Sorry about that.
  21. Ebbsspeed
    Ebbsspeed
    In a later posting he said anything from a stock bore to .060 over would be acceptable.
    I'd bet that TRWaters (HAMB Name) has a crate of 392 pistons on the shelf. I needed a rod for a 354, and he shipped one to me that even had the correct cylinder number stamped in the rod and cap.
  22. WhiteZombie
    WhiteZombie
    from Denton TX
    I have 8 Std. bore 392 pistons I pulled a while back. They could use a cleaning don't know if they can help you but I will be more than willing to help out a TX legend. And I'm just up the road in Sherman TX.
  23. pecker head
    pecker head
    & ! Back to the top !
  24. ChevyGirlRox
    ChevyGirlRox
    from Ohio
    Still on the hunt? I can check with a few of my sources today. Got to get you guys to Cacklefest!
  25. rodknocker
    rodknocker
    Hot Rod Gold !!! 392 Chrysler Hemi, A-1 block .030 over .Block is in great condition .It has been repaired at som point in its life and has 1 sleeve.\Fresh 20/20 crankshaft from motor wharehouse in sacramento, New bearings for crank ,cam and rod. Stock rods with Egge .030 pistons & stock heads and rocker ***embly.( all need rebuilding) .Also comes with stock pan center sump pan, starter, harmonic balancer and water pump pulley, spark plug tubes. head bolts, almost new adjustable push rods. Must SELL OR TRADE!
    Also have an NOS Weinand 6-71 blower. New ,never ran. Has early 1 pc front snout.Fresh polish. Email with any questions. What do you have to trade??? MUST GO ASAP !!!!! 209 743-2590 STEVE
  26. rodknocker
    rodknocker
  27. Rusty
    Rusty
  28. back up for Don...
    TH
  29. dwrfab
    dwrfab
    from Dallas TX.
    Group:
    Yea I said .040 or .060 over ,that was the first plan. We can sleeve the hole and use any size stocker. I have located two stockers withen 100 miles of Dallas and may have to go that way. A member of our group, Uncle danyel, is checking with Charles Smith and Mike Brown near Tulsa for one also. Still have some time.
    We also need a good standard thrust main bearing. Like I have said the car will not see any more hot p***es. Scot is the last guy to beat the Scorpion for all time to come.
    Thanks Don Ross
  30. blackrat40
    blackrat40
    Hey Don...any chance the burned piston could be welded up or did
    the hole go through the ring lands?
    Might work for limited "cackling" until Tinker can fix it right.
    MickeyD
