Technical scotts 12 bolt posi
Discussion in 'The Hokey Ass Message Board' started by aircoup, Dec 7, 2022.
  1. aircoup
    aircoup
    hello i have a scotts ?473 posi detroit locker in my 56 .in my opinion way too low geared for the street the trans is a turbo 400 with manual shift 3 speeds if i change the rear end gears to 373s what effect will it have on that trans except not having to shift so soon will it just give it longer legs for speed ?
    chevy57dude likes this.
  2. NoelC
    NoelC
    Longer legs, improved fuel economy and a risk you may not beat them all block to block.
    Desoto291Hemi likes this.
  3. chevy57dude
    chevy57dude
    Is the '56 in your avatar the one we're talking about? It probably weighs around 3500 ish pounds. What's your engine setup? Stock or stall converter? 3.55 or 3.73:1 gears would let the TH400 take you to 55mph at around 2300 rpm. While still getting out of the hole.
  4. indyjps
    indyjps
    aircoup likes this.
  5. 1934coupe
    1934coupe
    I'm a bit confused because I haven't heard of a 4.73 ratio for GM or 12 bolts. Is it a special ratio?
    Pat
    427 sleeper and Budget36 like this.
  6. Budget36
    Budget36
    I was just thinking the same, 4.56 I think I recall and 4.88.
  7. bobss396
    bobss396
    I run a 3.89 in my car with the M20, a bit wound up at 70 but has great acceleration.
  8. I have never heard of 4.73's either, 4.33's yes. But I know of a group of Mopar Stock Eliminator racers that got together and had some 470-somethings made. Also, if Aircoup has a 9" there are so many used NASCAR gear sets out there, it would make your head spin at the selection! Gene.
    seb fontana and aircoup like this.
  9. aircoup
    aircoup
    hahaha thats ok
    great its now 35 or heiher at 55 -60
  10. aircoup
    aircoup
    327 w 350 heads a nice cam dominator manifold and a 650 holley 301618666_7959626214109507_1161852301640782835_n.jpg
  11. chevy57dude
    chevy57dude
    Air, with those tall tires, I'll say 3.73s
    How far will you have to drive to Lloyd's?
    guthriesmith and aircoup like this.
  12. aircoup
    aircoup
    yes thats the one !!
  13. aircoup
    aircoup
    from what the seller told me yes its a scotts built rear center section !
  14. aircoup
    aircoup
  15. fastcar1953
    fastcar1953
    3.73 would put you about 3500 at 70 without o.d.
    aircoup likes this.
  16. twenty8
    twenty8
    How did you get that rpm without factoring in a tire diameter???
    You would be running a very small rear tire to get those figures.
    427 sleeper likes this.
  17. fastcar1953
    fastcar1953
    26 inch tall tire. about the dia. of a n50 15 tire
  18. 38Chevy454
    38Chevy454
    Something bugging me and I have to say it, your rearend is just a 12 bolt. Scott's is just the guy that built it. Stop calling it a Scott's rearend, it is simply a 12 bolt Chevy rearend. Plenty of previous replies have given you info on figuring out what gear ratio you can change to. Consider what your intended driving is, and then make changes to meet that. With some cam and being a 327, a 3.73 might be a nice choice as suggested. 3.73 is a common available gear for a 12 bolt. You also need to actually open the rearend and see what exact gear ratio you have, and what series carrier it has; probably a 4 series. Depending on the carrier, you may or may not need to get a new one 3 series.
  19. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Nice car aircoup!
    aircoup likes this.
  20. twenty8
    twenty8
    Ok. Yes, with a 26" tire you would be approaching 3500rpm doing 70mph with a T400.
    And yes, 26" dia. is quite a small tire.
  21. aircoup
    aircoup
    well thanks for the info yes 373s is what im going to do . a scotts is new to me but its what the guy that built it said it was so ...
