I don't know why, but the HAMB has shrunk to about 1/2 of my monitor widht, making it very hard for me to read.. (All other sites appear unchanged.) Can someone tell me how to restore it to normal size? Thank you.
I'd start by holding the CTRL key and scrolling the wheel on your mouse to see if that makes a difference. If you look at the bottom of your browser window you might see a small box that says 75%, 100%, 120%, or something like that which indicates magnification. Or you might not, depending on what browser you use.
Thanks for the suggestions. The CTRL/mouse scroll does bring it closer, making it readable. So far, CTRL and + has yielded no result. I am using Firefox. I will keep experimenting. The problem began suddenly a couple of days ago. What is odd is that the condition exists only on the HAMB. No other sites seem to be effected. I wonder if I could have changed some setting on the site???
Also try CTRL and 0 (zero). Should restore the screen back to 100% zoom. Your browser actually saves 'zoom' settings for different websites; I prefer a 95% zoom on the HAMB
Did you recently update Firefox or switch from using another browser? Have you made any changes to your browser's security settings?
Thanks for all the suggestions.. Control and zero yielded no results. I may indeed have altered my browser settings (inadvertently)...but it is curious that only the HAMB has been affected (so far as I know). Once again, Thanks for the ***istance. mo BTW, I am viewing now under CNTR/mouse Zoom.
