Technical Screw in PCV valves
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Jan 8, 2020.
  1. junkyardjeff
    junkyardjeff
    Installing a PCV system on my 235 and looking for a screw in PCV that I can screw in the va***n port on the intake and then run a hose to the blocked off road draft tube,I know the Ford Y blocks had one but did GM ever have one.
  2. lumpy 63
    lumpy 63
    Some late 60s sbcs had one that screwed into the oil fill tube on the intake. Try 67 Camaro for application.
  3. gimpyshotrods
    gimpyshotrods
    Wrong end. That was on the filler tube, and the hose went to the manifold.
    He wants the other way 'round.
  4. gimpyshotrods
    gimpyshotrods
    For 235's I got a core plug that fit the hole where the road draft tube goes (1-1/4", Dorman 555-024). I drilled a hole in it (3/4"), put in a grommet (Mr. Gasket No. MRG-6379), and put the PCV valve in there (Standard Brand V-237). A vented cap in the valve cover finishes out that end (Stant 10064).
    You can drill out the fitting under the carburetor, in the manifold, and tap it for 1/4"NPT, and run 3/8" hose between the two. Wrap you shop vac hose with enough tape, so that it fits in the carburetor pad hole, and leave the vacuum running when you drill and tap.
  5. inthweedz
    inthweedz
    Would these do the trick??, Looking at the application sheet, lower right hand corner, you're after the ''screw in manifold type, P/N CV609C'' ... this add was on Ebay..... 1962-64-Corvette-327-64-67-Nova-Chevelle-V8- 1962-64-Corvette-327-64-67-Nova-Chevelle-V8-Pcv.jpg
  6. DDDenny
  7. gimpyshotrods
    gimpyshotrods
    Find one that replaces GM 916337, 3916338, 3916339, 3829058 & 6419553.
    The one that went with the one that was used with the road draft tube replacement is the one where the threads are on the manifold or carburetor end:
    The one that threads into the filler tube is the one that won't work properly:
    VANDENPLAS, scotty t and loudbang like this.
  8. I used a BBC valvcover pcv gromet in the road draft tube hole on an sbc with a standard pcv valve. It worked fine. Some of the other options listed above are probably better, but I thought I would offer this method anyway.
    scrap metal 48 likes this.
  9. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Nailhead Jason and scotty t like this.
  10. Fairlane3x43
    Fairlane3x43
    from Michigan
    I used the AC Delco one that screws into the back of the carb. and it blew my motor apart. The small metal plunger inside the PCV came out and was ****ed into the manifold. Then went into the cylinder and was hit by the piston which then cracked the cyl. wall front and back when it tried to push it up. 1966 , 327 fresh bore, new pistons, align honed etc. $5.00 part cost me $3200. I now put the PCV in a freeze plug that I put in the draft tube opening. Drill and tap for screw in PCV then a 90 degree fitting just in case. Hot Rod carbs sell the grommet that goes in the hole too.
  11. jimmy six
    jimmy six
    That’s the one I’ll be using on my GMC. I’m also using the Camaro fill tube the side and a hose fitting in the side pipe thread. I like the sealed top of the Camaro oil fill tube and that it will fit in the Chev/GMC block.
  12. jimmy six
    jimmy six
    It needs a L79 air cleaner to float my boat.
    scotty t likes this.
  13. DDDenny
    Jimmy
    The open element air filter was standard issue on the 67 Nova and Chevelle L79 and 66/67 Corvette engine option.
  14. jimmy six
    jimmy six
    OK but I like the 2 side ovals. Just screems L79...:)
  15. RMONTY
    RMONTY
    This doesn't help you by answering your question about screw-in valves, but it is a pretty informative how-to with a lot of research behind it I think.
    http://devestechnet.com/Home/PCVInstall
  16. DDDenny
    Like this?
    deathrowdave and jimmy six like this.
  17. Mark Wahlster
    Mark Wahlster
    Check out Walcks on line Willys CJ's and 4cly powered Kaiser CJ's used a screw in PCV with 1/4" NPT threads.
  18. Chief 64
    Chief 64
    gimpy,
    Do you know where I can buy this. This will fit 327 right?
    Thanks
    Greg
  19. gimpyshotrods
    gimpyshotrods
  20. Chief 64
    Chief 64
    Thanks gimpy! That kit looks like a clean way to go.
  21. gimpyshotrods
    gimpyshotrods
    Yup. The breather on the fill tube remains the same, and this replaces the road draft tube.
    Lust run the hose to a manifold vacuum port, and you're all done!
    Chief 64 likes this.
  22. jimmy six
    jimmy six
    Bought mine at O’REILLYs
  23. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Do you have the oriellys part number#? If so share it with us. I need to buy a couple extras.
