Technical Screw removal HELP!!!
Discussion in 'Traditional Hot Rods' started by Al, Mar 9, 2018.
  1. Al
    Al
    from Duluth, Mn
    I bought the front part of a 37 hood off ebay that has the handle, and the parts I need for the hood. There are two small screws that are rusted. I need to remove them from that pot metal ornament. The screws are whole right now. Any idea as to how to take them out?? I have the 50/50 blend of ATF and Acetone on it. Can I heat that pot metal with a propane torch to try to back those screws out?? Thanks
  2. DDDenny
  3. evintho
    evintho
    ^^^^^What he said!^^^^^
  4. Hnstray
    Hnstray
    from Quincy, IL
    IF heat is used, focus heat on the screws, not the pot metal...........then let them cool, use PB Blaster or like before trying to remove them.
    Ray
    49ratfink and Barrelnose pickup like this.
  5. Unkl Ian
    Unkl Ian
    Pot metal doesn't change color, before it turns into a puddle.
    Be VERY careful.
    oj and 49ratfink like this.
  6. Al
    Al
    from Duluth, Mn
    I have that also. Does not really want to move. I put a screwdriver into the slot, and gave it a rap but it is still frozen. Should I heat those screws up and then throw it in the snow. Then try to take the screws out??
  7. rusty valley
    rusty valley
    hnstay has it right, you heat the screw, with a small tip on your oxy/acet torch, and let it cool naturally. the heat makes the steel expand, forcing the threads deeper into themselves, then contract when cool to give some space to move. a little "shock" with a hammer to tell the inanimate sob you are a superior being, and will win helps
    Special Ed and Texas Webb like this.
  8. belair
    belair
    And if possible, when you do get ready to try take them out, try to tighten them first. It may loosen them, and if you're going to mess up the slots on the screws, do it on the sides that that you won't need to take them out. I hope that makes sense. Tap on the end of the screwdriver as you turn it, too.
  9. rusty valley
    rusty valley
    good point, tighten first a lot of times works
  10. gene-koning
    gene-koning
    Sorry, its pot metal with steel screws. I think the outcome won't be good, but I guess you really don't have anything to loose.
    Heat anywhere near pot metal scares me. I wish you the best of luck. Gene
    trollst likes this.
  11. lonejacklarry
    lonejacklarry
    All I would offer is to not be in a hurry. It probably took 40 years, or more, to seize up. I use Kroil and spray once every 2 or 3 days. Heat it up and spray some more. If you take your time you might be better off.
    chiro likes this.
  12. BJR
    BJR
    Try all of what has been posted so far and then heat the screws up with propane torch and melt a wax candle on the threads. As it cools it will wick the wax into the threads. Then try to remove after the part cools.
    Andy, oj, Hollywood-East and 3 others like this.
  13. Gandalf T Grey
    Gandalf T Grey
    I would try a "hit with a hammer" type impact driver with a Very snug fitting driver bit first. As said above, one or 2 taps to tighten first, then reverse to loosen. If you need to heat it, heat up a 3/8" Steel rod red hot, then place the end of the rod on the head of the screw to transfer heat Only to the screw. Hose it down with your favorite penetrating oil while it is cooling so it will draw the liquid in as it cools. Try again with the "hammer" driver once it is cooled down.
    If the head strips out, or breaks off, then it is time to reach for the DC Tig welder. We get a lot of broken bolts at work, and the TIG is our GO TO machine for getting them out. Get a puddle going on just the end of the fastener to be removed, and hold it there a while to get some heat into it. The idea is to put enough heat into the fastener to get the rust on it to change form (FeO2 .>FeO3 red rust to grey oxide ), and to have it shrink when it cools. If the fastener is broken off, I use a stainless tig rod to build it back up. 310 & 312 work the best. We build them out until you can weld a nut onto them to try turning them again. Patience, and a steady hand are required, but we haven't been skunked yet.
    ckdesigns, Hollywood-East and ZAB like this.
  14. Bandit Billy
    Bandit Billy
    This thing ^^^^^^
    49ratfink likes this.
  15. DDDenny
    I don't see this approach ending well!
    Maybe one of those little plastic hammers in Jr's tool box.
  16. big duece
    big duece
    from kansas
    If you do use a propane torch, just get it warm enough to lay a birthday candle on the threads and let the melted wax creep in the threads, I am a believer in that method.
    Andy likes this.
  17. Marcosmadness
    Marcosmadness
    Take it to a machine shop that has a EDM. The EDM will make short work of Getting the screws out. It will cost a little money but it won’t destroy the part.
  18. Speedwrench
    Speedwrench
    An old machinist showed me a trick that worked well on frozen fasteners.
    Buy some oil of wintergreen and apply to the screws and let it sit for a few minutes to soak in. you should be able to remove the fasteners as if there had never been a problem.
    rfraze likes this.
  19. 37 caddy
    37 caddy
    from PEI Canada
    if the hood is not usable,can you cut the pieces away so you have just the handle,it would make it easier to get at the screws,maybe use a pair of vise grips to turn them?
  20. CadMad
    CadMad
    Best trick I know is to oil up the thread and then mig buzz the head of the screw or bolt a few times to build it up and then tack on another bolt on top and give it a gentle turn. It never fails me.
    saltflats likes this.
  21. woodscaper
    woodscaper
    Put a little valve grinding compound on the tip of the screwdriver to give it a little grip
  22. RICH B
    RICH B
    Tread lightly, if you use one of those hammer slammer impact drivers; they can easily twist screws off if hit too hard. Almost seems counter productive tapping on something that begs for a hard hit; but it will get you there.
  23. sloppy jalopies
    sloppy jalopies
    I use heat, but just the screw, gotta heat it enough to get to the threads, every time you heat it it shrinks the bolt a little, you can let cool and keep repeating till it shrinks enough to break free...
    IMO... don't try and break it loose while red hot, the screw expands when red hot and jams the threads, you can also strip the slot.
    I lay the screw driver in one end of the slot, tap it from the side with a hammer to "clear" the slot, repeat in the opposite direction...
    then tap on the end of the driver to sort of shock the threads...
    then I twist the screw in the "tighten" direction, so if it doesn't let go I don't strip the slot in the loosen direction... if it doesn't release repeat the heating prossess....
    I really like sili kroil now called areo kroil... $20 a spray can........HIH.
  24. deathrowdave
    deathrowdave
    from NKy
    Auto trans fluid and Acetone 50/50 is best , it will harm paint . Sometimes all of the above suggested paths to remove rusted fasteners has no bearing on fused hardware in the rust belt . EDM or mill cutter and retread may be your safest part saving idea .
  25. khead47
    khead47
    Kroil is the ****z !
    oj likes this.
  26. Al
    Al
    from Duluth, Mn
    Last resort would be to snap them off, and drill it out and put in larger screws. I would rather just back them out though.. I will keep on doing all of the above. Thanks for all of your help.
    doug j likes this.
  27. trollst
    trollst
    I feel your pain, you're up against the dissimilar metals thing, they are literally welded together, you may never get them out short of redrilling.
  28. butch27
    butch27
    I have used a small torch used for soldering -pin point or something ??
  29. Terrible80
    Terrible80
    Can you sacrifice the screws? Just drill the heads off. Save the piece.
    Sent from my LG-TP450 using The H.A.M.B. mobile app
  30. oj
    oj
    Like another said, heat and wax. I prefer beeswax over candlewax, heat the screw and let the besswax soak into the screw threads.
