Technical Screwed this intake?
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 5, 2022.
    pipe fitting busted flush with the intake. That way when I got it. Warmed it up and used an extractor.
    Busted it out. :(
    SBC large base 2v intake. Kinda hard to round up.
    dana barlow likes this.
  2. At least you got the offender out. Now "V" it out and weld it. Bolt it to a head to use the head as a heat sink, and lessen any possible warping.
  3. guthriesmith
    guthriesmith
    I may have a few of those laying around as well if you want to swap it out.
  4. It’s still in there. I’ll guess I’ll have to drill it out now.
    Nickel rod with a stick after a preheat.
    Or silicon bronze with a TIG
  5. Silicon bronze will work very well,,,,,whichever you prefer really .
    Tommy
    mad mikey and anthony myrick like this.
  6. Thanks.
    My disappointment is wearing off. I will probably rev up the TIG.
    It’s not under any pressure just the PCV elbow.
    Bandit Billy and Stogy like this.
  7. Anthony,
    My guess is where the fitting was screwed in so tight,,,,,and it being a taper thread fitting,,,,,the heat made the iron bust open .
    Get that piece out,,,,,close her back together,,,,,,and the bronze should make it look like it never happened .
    Tommy
  8. I’ll give it a go. Have nothing to lose.
    I’ll be extra careful tightening the fitting.
    My TIG is at school. Might have to swing by on a Sunday:)
    Stogy and mad mikey like this.
  9. Once you repair it,,,,,,it should not happen again .
    Tommy
    Stogy, mad mikey and anthony myrick like this.
  10. squirrel
    we used to work so hard to s**** those intakes....no, I don't have any left.
    pnevells, guthriesmith, Stogy and 3 others like this.
  11. Tell me about it.
    I never would have thought I would have got excited over locating a 2v iron intake.
    I’ve got a small base intake but I lucked into a good carb and intake setup.
    Its for an early 60s flat bed. Not hot rod parts needed here.
  12. What year is that intake? I might have one. You can have it for shipping if I have one.
    5window and mad mikey like this.
  13. Got one for my GMC flatbed as well! After welding you can hit it with a needle scaler then blast and you will never know it was fixed.
  14. Mr48chev
    To get that broken pipe end out, take a hack saw blade and cut a couple of slots just through to where you figure the inside of the threads are in the pipe, do that in a couple of spots and then take a small chisel and knock the piece out and then you can get the rest of it out. You don't cut though the pipe just to the back corners of the threads that are cut in the pipe to create a weak spot to knock out. About 90 degrees or less from each other.
  15. I’ll tackle that probably just like that or close anyway.
    V-grove the cracks and TIG.
    The part that got me the most was that this was the last thing we tackled. Carb built, electric choke swapped over, removed the electric fast idle and the vacuum choke manipulators and extra unneeded holes plugged. Gaskets and sealant purchased.
    This intake doesn’t have a temp sending unit provision so we used the heater hose fitting. The heater core is shot so we’ll tackle that issue later.
    It was down to this broke fitting and some rattle can. ****.
    I’ll live to fight another day.
  16. manyolcars
    manyolcars
    The Henrob torch is excellent for welding cast iron
    anthony myrick likes this.
  17. Ebbsspeed
    Ebbsspeed
    Those extractors that screw in backwards to remove stuck threads also exert outward pressure, and if you had it hot enough the stuck threads probably swelled when you cranked on the extractor and split the iron.
  18. More than likely.
    Lesson learned.
    I just removed a broke bolt from a hub with the extractors but that’s a better quality material than cast iron.
    Stogy likes this.
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    Just blast what's left of the fitting out with your cutting torch ,easy peasy !.
    alanp561, squirrel and anthony myrick like this.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Try finding kick down cable bracket for a 2 barrel. :( Took me a while :)
  21. Well this will fix the sending unit location issue.
    I’ll remove both pipes, plug the forward one and use the side one for the temp sending unit
  22. Yep
    das858, Desoto291Hemi and oldsjoe like this.
  23. oldsjoe
    oldsjoe
    Nice work! Joe
  24. This intake came off a truck my uncle ran for decades. He p***ed a couple years back. Guy could build and weld anything. I almost thought he welded this fitting.
    mitch 36 likes this.
  25. 1-SHOT
    1-SHOT
    from Denton
    You can TIG weld it with ER309L stainless. But you will need to thread a carbon insert in the whole first. It welds like spreading ****er, the problem is it is extremely hard to drill and tap. You need a carbide tipped drill bit and when you thread it you can only go a 1/4 turn at a time and back up ar the tap will freeze and you will break it off. I have welded a lot of ears back on blocks and the carbon insert is the only way to go back the carbon insert and clean the holes with a tap.
    loudbang, alanp561 and anthony myrick like this.
  26. Grooved it. Pre-hear it. TIGed it.
    E5722B36-BC4A-40C7-8B8A-CA828C9C7075.jpeg 395032F0-3C81-4083-8903-C650EF7F8F6A.jpeg BB559F45-8F28-4C5B-A2DF-1599E4A0F227.jpeg
    little more cosmetics then clean up the threads
    Cosmo49, Stogy, das858 and 6 others like this.
  27. Guy Patterson
    Guy Patterson
  28. Perseverance! Good work.
    Stogy and anthony myrick like this.
  29. Nice work. I would have tossed it in the trash thinking it was useless. Nice to see something saved :)
    Cosmo49, Stogy and anthony myrick like this.
  30. We did a pre and post heat with a torch.
    First time to TIG on cast iron.
    Not much to it
    Cosmo49, Stogy and squirrel like this.
