Folks Of Interest Screws in reverse smoothie wheels?why?
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Jan 11, 2020.
  1. iwanaflattie
    iwanaflattie
    Hi.
    I was too excited to buy these reverse smoothies that i didnt see the screw holes on the bead rim.
    Why would anyone do that?
    So the tires dont fall off?
    6 in the ones with the slicks and 4 in the ones with no tires.
    Tia 72a5df61f37d41dcb007810637464a7c.jpg 31f67be3beb0443887ec4b7029952269.jpg
  2. scrap metal 48
    scrap metal 48
    Being slicks, maybe to keep the tires from spinning on the rim...
    wraymen, fauj, gnichols and 13 others like this.
  3. Speed Gems
    Speed Gems
    It's done in drag racing a lot so the rims don't spin inside the tires if you have a lot of torque.
  4. J'st Wandering
    J'st Wandering
    Bingo
  5. squirrel
    Most of the time it's just copycat of what the "pros" do...they aren't need on most cars. But it impressed the kids at the drive in during the 1970s-80s.
  6. willys36
    willys36
  7. iwanaflattie
    iwanaflattie
    Can they be tigged to patch them up?
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    the holes will not hurt anything, they will not leak air there. If you weld em, then they will need to be re chromed..... btw those are not chrome reverse wheels. they are commonly known as chrome smoothies (note there are no vents between the ctrs and the rim)
  9. squirrel
    JC Pennys slicks! those are rare.
  10. willys36
    willys36
    Put sheet metal screws in them when the tires are on and look macho.
    Because of this. But chances are they where for looks.
    Just put some fancy screws in the holes and play the tough guy part
  12. iwanaflattie
    iwanaflattie
    Thanks for all the info.
  13. harpo1313
    harpo1313
    from wareham,ma
    That slick looks downright angry ^^^^
  14. squirrel
    Fast cars these days use beadlock wheels, not screws in the rim.
    lothiandon1940 likes this.
  15. gimpyshotrods
    gimpyshotrods
    Are you going to use the slicks?
    chevy57dude likes this.
  16. gimpyshotrods
    gimpyshotrods
    Put screws in with red Loc***e. Cut off the excess on the inside, being careful to not generate too much heat, spin the screw, or gouge the lip.
    quick85, Hnstray and belair like this.
  17. Mr48chev
    That was probably done just about the time some rod magazine ran a story on it in the 70's I think. I remember the story but don't remember what magazine or exactly when.
    Spooky likes this.
  18. iwanaflattie
    iwanaflattie
    Probably not..id save them for garage art tho.
    great idea.
    These wheels look super new...i didnt think they be that old
    mitch 36 likes this.
  19. Blue One
    Blue One
    from Alberta
    Yup, not chrome reverse wheels.
    Maybe you got screwed more than once :eek: :D
  20. RmK57
    RmK57
    Mostly just see them if you run inner tubes with slicks. If you run tubeless no need for them or not as much need.
    reagen likes this.
  21. iwanaflattie
    iwanaflattie
    What brand could they be?
    They are stamped "15X6 MADE IN USA" and something like "WELD"
    A 94 inside a circle...any ideas?
    5 on 4.75
  22. Blue One
    Blue One
    from Alberta
    Weld is wheel manufacturer.
    https://www.weldwheels.com/
  23. 1320 Fan
    1320 Fan
    early beadlocks!!
  24. goldmountain
    goldmountain
    COCONUTS, Hnstray and Lil32 like this.
  25. The37Kid
    The37Kid
    Dirt track cars in the 1930's used them, nothing new. Bob
  26. iwanaflattie
    iwanaflattie
  27. error404
    error404
    from CA
    cheap beadlocks
  28. rustydusty
    rustydusty
    We used to put screws in the rear rim of our motocross bikes back in the '70s...
  29. Beanscoot
    Beanscoot
    For what it's worth, I've used grease when mounting tires on rims for a couple of decades now, with no problems of tires spinning on the rims so far. But I'm not racing.
  30. loudbang
    I HAD to use them back in the 60's. New M&H slicks with tubes on a OT late 60's car. I was advised to mark the rim and tires and watch the valve stem. Sure enough after several burnouts and runs the paint and valve stem showed the slick was slipping on the rim that was mounted with no lube. Installed the 6 screws and never a problem with slick slippage again.
