Scrounging metal & iron
Discussion in 'The Hokey Ass Message Board' started by flatford39, Mar 16, 2008.
  1. flatford39
    flatford39
    Where do you guys go to get all the steel that you use to build vrious projects. I know I can buy it but I would like ideas on where one can go scrounge it up. I hate paying for things, but I won't steal.
    Thanks
  2. I get my metal to weld up projects from farm auction sales. Usually the chunk of metal is on a large pile that sell to the s****per dude. Then later on in the auction, you can talk to the s****per and offer him cash for just the piece that you want. This works for me all the time. Also, sometimes when I have to bid to win an item that I want and it includes more junk than I want to take home, I just give the rest to the s****per guy. It is a good way to make friends with the guy for future auction event outcomes.
  3. lostn51
    lostn51
    from Tennessee
    i dig in the s**** bins at my friends sheet metal shop or use the left overs from fenders hoods and whatnot i have left over from other projects.
  4. 56Sedan
    56Sedan
    I used to work at a large fabrication shop, I'd raid the s**** dumpsters daily and get what I needed or thought I would need down the road.
    I still hit up machine shops, and sheet metal shops. I usually drive my '56 up there and once I explain what I'm looking for they tell me to get what I need and usually only have to pay a few bucks.
    Sheet metal shops have lots of s**** that is good for what we would need, but useless to them.
  5. Old bed rails for 1 1/4" angle iron.
  6. Brad54
    Brad54
    from Atl Ga
    The local junk yard/recycling center has finally started to accept s**** steel and put it out--in big, ugly piles--for us to pick through. A lot of it has gone, too, so guys are digging through it and buying it. I bought a 3x4-foot piece of 3/16-inch plate and then a 3x5-foot piece of 1/2-inch for .20 cents a pound. (welding tables!). Got a piece of 1/4-inch 2x4 box tube for legs and a round disc of 1/4-inch for a shot bag station too. Just bought a piece of C-channel yesterday for .25 per pound. It weighed a 56 lbs, while the 1/2-inch plate weighed over 350lbs. Gonna be a BIG honkin' welding table!
    So, check your local recycler.
    -Brad
  7. duste01
    duste01
    recycling center is great for metal around here, course I send stuff from work there too.
  8. Dwayne, you of all people should know that bed-frames are made from heat-treated high strength, high carbon spring steel.....
    and when welded the welds will be brittle like gl*** when even lightly stressed...and drill bits and saw blades will quickly dull when trying to work the stuff....
  9. couple of tips....industrial s**** bins behind welding/machine shops....after hours or most shops will let you scrounge thru if you throw them a couple of bucks....s**** yards pay little or nothing to them as they have to drop and pick-up the bins...
    also, I go to the big s**** yards on Sunday when they are closed....a lot of folk just drop stuff off outside as a dump site after hours....so it's a free-for -all....I've gotten hundreds and hundreds of pounds of good iron shopping that way....
  10. I have the local s**** guy dropped by my house before he takes the load to s****..
    Never know what your going to end up with..
  11. Ruff T
    Ruff T
    from NJ
    I go to my town dump every Saturday. They allow you to take whatever you want for free.
  12. zbuickman
    zbuickman
    dumpsters at work. there all seperated too. plate, plate 1/2 and up, sheet metal and stainless:)
  13. Belchfire8
    Belchfire8
    We use tons of 3/16" cold rolled and all sorts of angle at the die shop i work at, simply walk to the s**** bins and dig. My brother use to at a large fab shop, like one where they fab buildings and overp***es. He was a great source of "s****' steel. I'd suggest talking to anyone you know at a fab or machine shop, they can peobably get stuff cheap, or free for you.
  14. no bux rod
    no bux rod
    Ditto to Goober's idea. I buy my bedframes at local thrift stores. Goodwill is a little pricey at $14.00. The store I use has them for $3 to 6.00 and you get 15-25 feet of 1/8" angle iron. Queen and King frames are the best choice. I have seen flanges from 1.25" to 2" Currently have 3 in stock.
    N B R<O:p</O:p
  15. von Dyck
    von Dyck
    Consider transmission/driveline shops: they throw out a lot of dented or bent driveshafts. Usefull for straight sections of exhaust systems, if for no other reason than to get you running until you can afford the stainless set-up.
    Discarded bicycle frames: lots of interesting smaller diameter thin wall stuff here. Also bike spokes make a variety of picks, hooks and special app. springs when wound around a screwdriver shank - that stuff is good steel.
    Short lengths of thin-wall tubing is found in worn-out shock absorbers.
  16. ray-jay
    ray-jay
    from Buford GA
    The local recycling center where I live will NOT sell you anything. When I had my shop there was a s**** metal yard across the street and I got a tremendous amount of STUFF from him. Everything from cool old motorcycles, to alum s**** from machine shops, steel of all varieties, and a lot of good running V8's.
