SDRA 6 CYLINDER DRAGSTER (Please Remove Ad)
Discussion in 'Cars For Sale' started by Old28, Jun 10, 2014.
  1. Old28
    Old28
    City: Bakersfield
    State: California
    Price: $4500 Firm
    SDRA / HAMB Style Dragster HOPE IT GOES TO SOMEONE THAT CAN HAVE SOME FUN NOSTALGIA RACING, YOU WILL NOT FIND A TURN KEY DRAGSTER FOR LESS MONEY.
    ****** FINAL PRICE --- $4500 (Good For Two Days)
    Dragster goes into storage (Oct 1) To Part out.
    Medical Forces Sale (hip problem stops me from getting in/out of seat)
    Complete race ready/turn key SDRA dragster
    MOTOR --- Chevy 194” 6 Cylinder – small chamber 194 heads – fresh rebuild –New SBC 1.84/1.64 In/Ex valves – head milled .060” – stock FT piston & rods – Clay Smith .500/.500 lift solid cam – Screw in rocker studs – 1.7 BBC aluminum roller Rockers – aluminum valve & side covers with breathers – Pertronic ign – after Market 2x4 intake w/adapters – dual Holley 94 carbs (fresh pro rebuild) – custom Headers (pair of 3 into 1)
    TRANS – Aluminum 2 speed PG – 9” 5500 V8 converter – SFI flexplate & cover
    REAR END – Mustang 8.8 rear end – solid frame mount – 3.73 (5 passes) – Ford Traction lock center – Moser C clip eliminator bearing on each axle – rear drum
    MISC PARTS ON DRAGSTER – Wilwood master brake cylinder – Durflow aluminum radiator – 5 point belts (current cert) – Battery kill switch in rear – full gauges and switches – Alum body – legal rear tail light – custom electric water pump drive – drilled ford front axle – Friction shocks on front – Optima 12V battery – roll cage approved NHRA 10.00 – slower – Passes NHRA tec inspection – full floor & trans cover – full 360 degree 3 pc drive shaft cover (NHRA approved) -- -new mini starter – aluminum F/C seat with black cover—QR steering wheel
    EXTRA PARTS WITH PRICE --- Chevy 250 +.040 Bare 6 Cylinder Block -- Clean Crank From This Block -- 6 Rods/Pistons From This Block -- Stock Oil Pan -- 2 Sets Side Covers (1 chrome, 1 plain) -- Spair (new) Moser Axel Bearing -- One 6 Straight Tube Zoomie Header.
    May trade turn key dragster with some cash added towards a fenderless A Coupe or Sedan. What do you have? I like banger hot rods also.
    Tom --- 661-859-8955 or 661-587-6087
    email -- tdracing7695@yahoo.com
      111.4 KB
      111.6 KB
      147.4 KB
      122.6 KB
      119.4 KB
      111.5 KB
      90 KB
      102.8 KB
      99.3 KB
      95 KB
      125.5 KB
      113.6 KB
      114.8 KB
  2. Old28
    Old28
    Dragster going in storage.
    Moderator Please remove the AD
