Technical SE Gasser air intake rules?
Discussion in 'Traditional Hot Rods' started by Roadhog56, Sep 1, 2025.
  1. Roadhog56
    Roadhog56
    Guys, I have a 47 Ply , built according to the rules of the SE G***er ***oc. The engine is set back requiring the firewall to be set back. This allows for the p***enger fresh air intake to put air directly into the engine compartment. Would the SE g***er rules allow an air plenum built on top of the carbs to direct flow into the carbs? THANKS,!
  2. 37gas
    37gas
    Ask southeast g***er or look in there rule book
    Just Gary likes this.
  3. oj
    oj
    Is this a race only build? If 'Yes' then the air cleaners and that box etc need to be replaced with a sealed fresh air intake mating up to the hood scoop, the carbs need fresh air and lots of it. You don't want the scoop etc to be behind the carbs, the air source needs to be slighly ahead of the carbs, air has weight and as the car goes down the track you don't want the air piling up behind the carbs. A good scoop and carb pan can easily cut a tenth off the ET.
    sidevalve8ba and Just Gary like this.
  4. Roadhog56
    Roadhog56
    I should have stated I did read the rules, which are not clear on this issue because they talk about "hood scoops and don't mention "cowl scoops". I also sent a message to SE g***ers explaining my intention but haven't received a reply, so I did my homework before posting here!!!
    seb fontana likes this.
  5. Roadhog56
    Roadhog56
    This is not a race only and I have found a few other issues that may not be allowed that can be easily fixed. I will probably never get it to the track but wanted it to conform to the rules for resale value if I ever sell it. Thanks Ed
    MAD MIKE and alanp561 like this.
