Sealing gas sending unit.
Discussion in 'The Hokey Ass Message Board' started by Stevie Nash, Oct 29, 2013.
  1. Stevie Nash
    Stevie Nash
    Just got my 37 Nash gas tank refurbished. I need to seal the sending unit and there is not a replacement gasket available. I will need to make a gasket. I know cork is resistant to gas, but can I use it to seal? I'm afraid it may breathe too much...??? Suggestions?
  2. gas pumper
    gas pumper
    liquid permatex on the cork.
  3. jkeesey
    jkeesey
    use HYLOMAR on the gasket. Every sender I pull out has gooey permatex all over it. The permatex can come loose and clog up your fuel system while the hylomar is fuel proof. It does not harden either.
  4. CURTL
    CURTL
    from Michigan
    Buy a roll of rubberized gasket material and make your own . Mr gasket makes one that is made for gas and oil . I don't use any type of sealant only a gasket .
  5. blue 49
    blue 49
    from Iowa
    I've used tank sloshing sealer with good luck. Put it together wet with some on the screw threads, too.
    Blue
  6. fsae0607
    fsae0607
    This. You'll thank yourself later when you need to replace the sender in the future.
