i have seen a clear bead material used around quarter windiows on woodies does any one know what it is - name brand =thanks for info
The beauty of the 100% Clear Silicon caulk is it's chemical make up allows it to expand and contract with the weather conditions. HRP
and you can use it apply a patch to the hole in your coat,,,seam sealer has a variety of uses as a adhesive because it sticks to everything...I keep a tube in my boat also
The problem w/ clear silicone sealer is it photochemically degrades over time [turns yellowish] supposedly it still works fine ... but... a clear caulk that doesn't yellow is marketed as "LEXAL" high priced but works well .. [ it's an elastomeric copolymer] dave
