Seam Sealers
Discussion in 'The Hokey Ass Message Board' started by DiabloMann, Jan 19, 2007.
  1. DiabloMann
    DiabloMann
    from colorado
    What are some good seam sealers to use and that are paintable. Is epoxy the best?
  2. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Aveico was the industry standard forever.
  3. 49ratfink
    49ratfink
    funny you should ask... I just got done doing some seam sealing on my 57 around the new wheel tubs.
    I like 3M "Fast n' Firm" # 08505. I have used it on several projects with nothing bad to say about it.
  4. i like fast n' firm too...i just wish i was still that way too
  5. Dirk35
    Dirk35
    I used one of the 3-M ones. It was the brushable one (thick as hell, but it was actually brushable). Painted right over it, no problems.
    I only have put DPLF 50 (50 is the grey, 90 is the black, right?) over it. Been a little over two years painted, havent gotten around to shiney paint yet.
  6. Reds 29
    Reds 29
    I painted over some "fast n firm" 5 years ago and now the paint has cracked in quite a few places. I would be careful where I used it, if I use it again.
    Red
  7. HotRodFreak
    HotRodFreak
  8. fordcragar
    fordcragar
    from Yakima WA.
  9. ray
    ray
    from colorado
    you lead your floorpan and wheelwell seams? you're ****in ********.;)
  10. SEM makes agood product. A little pricey and you need a special gun (like a caulking gun) to apply it. It won't crack and can be sanded and painted.
  11. bosskustoms
    bosskustoms
    from bc
    If you want a seam sealer that won't crack, you have to use a 2 part seamsealer. 3M, SEM, Fusor, are just a few companies that make it. It comes in two tubes (attached to each other) that mix in a special tip while you are applying it, you need a special gun to apply it, your local jobber should lend you one, if you buy their product. paint can potentially crack when you put it over any one part seamsealer because the one part seamsealer expands and contracts more than the paint will, there are lots of situations where paint hasn't cracked over one part sealer, there are also lots of situations where it has, if you want to use one part sealer, put flex additive in BOTH your primer and paint, this will help prevent cracking. Also a tip while sealing, put some wax and grease remover (cleaning solvent) in a squirt bottle, when you apply the sealer, before you smooth it out with your finger, or brush squirt some wax and grease on it so it's wet, it makes the sealer waaay nicer to work with.
  12. DiabloMann
    DiabloMann
    from colorado
    Thanks for the advice and tips!
  13. K13
    K13
    Evercoat makes a two part seam sealer that works in a regular caulking gun.
