Hot Rods Searching for a Ford 3 window
Discussion in 'The Hokey Ass Message Board' started by Derek Dandurand, Jun 14, 2021.
  1. Derek Dandurand
    Derek Dandurand
    Last known whereabouts is cape cod M*** in the early 60s. it had a 39 transmission with zephyr gears, had a small block Chevy engine, 37 truck grill. Same car I’ve been looking for for years. It was my grandfathers hot rod he built between 54 and 57. His name is George Smaldone. You can find him posted by me throughout the HAMB
    alfin32, catdad49 and kidcampbell71 like this.
  2. oldiron 440
    oldiron 440
    I see these posts from time to time on most of the automotive forums I'm on and can't help but wonder if the car is like it was back in the day or has been completely redone a half a dozen times and had twenty owners.
    It's a cool ride good luck with your search.
    stillrunners likes this.
  3. stillrunners
    stillrunners
    from dallas
    What oldiron 440 said - I always look for my uncle's 1949/50 built Bonneville roadster he finally sold in 1962 in Cali. It was unquiet with his own Duvall type windshield - something that could of - and most likely was changed . He saw it shortly after signed off on the pink slip with a new set of American's on it instead of his old chrome caps.
  4. Derek Dandurand
    Derek Dandurand
    The next step is to perform historical research at the DMV. I have three years it was registered to my Grandfather and his address at the time. If I can get the ch***is number/serial number/or ***igned vin then I can locate at least where the frame went!
    dana barlow, Hamtown Al and catdad49 like this.
  5. Thor1
    Thor1
    Derek, I'm not sure what the rules are where you are located, but here in Wisconsin, it is hard to almost impossible to do what you are describing. If you are a member of law enforcement you can get access to the DOT database of registered VIN numbers, but a civilian cannot. Also, I believe the LEO's can only search the database as it relates to law enforcement - for example, if you have a buddy that is a police officer he cannot legally look through the database on your behalf to find a car.
    It may be different elsewhere, and I may be talking out of my backside about the rules here, this is just my understanding from having had this exact same conversation with a friend who is a police officer.
    Budget36 likes this.
  6. Derek Dandurand
    Derek Dandurand
    thanks for the notes. RI does allow historical research. I spoke with the archive. They have to perform the search though as I will not have the authority to see all the records. I know the plate numbers and the address my grandfathers had. They are likely all on microfilm which will take a while!
    kidcampbell71 and Thor1 like this.
  7. Derek Dandurand
    Derek Dandurand
    Update: it was showcased at the 58 hot rod and customs worlds fair in Springfield MA! Although this calls the car a 1934 not a 33 as I previously thought!
  8. Budget36
    Budget36
    The same here and as it should be.
