Seat Foam for buckets?
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Jul 26, 2010.
  1. scootermcrad
    scootermcrad
    Hey upholstery peoples! I need a little help. Building some bottom seat cushions for my bucket seats (sort of bomber style). They will need need to be slightly contoured at the front for leg support/comfort, so it must be shapable. I'm trying to figure out what the CORRECT foam should be that won't break down after a month of bouncing around?
    The foam will probably only be an 1-1/2" where my rear will be and then increase for a support bolster towards the front; maybe 2-1/2". There will be stuffed rolls over the top of that, so really the foam will be just for support.
    Am I looking for a firm-extra firm type foam??
    Any help would be appreciated. Didn't see much doing a search.
    Thanks!
  2. ken1939
    ken1939
    The green foam is the most dense. I think for your application it might be one way to go. You can shape the foam with an electric carving knife. You could also build layers of foam to make the basic shape to feel good to sit on and fit the seat.
  3. scootermcrad
    scootermcrad
    That sounds like the ticket! Is there an actual name for this stuff?? I've done several internet searches and come up with a large array of foam products, and haven't run across this stuff specifically yet. Is it a Polyurethane foam??
  4. scootermcrad
    scootermcrad
    Another foam that I see once in awhile is the composite looking foam (or whatever the hell it's called) that looks like it's made of several different type of foam pressed together and is mostly gray in color. Is that similar, better, worse, or just different than the green stuff mentioned above?
  5. Go to a Craft store like JoAnn Fabrics, they have many different types of foams available in sheets. They will also have the Burlap and what ever you need to cover and attach.
    Tough part is walking in with the wife or GF into a craft sewing store
  6. BigEd
    BigEd
    There are some excellent threads on this topic on the hotrodders.com forum. The moderator for the interiors threads is very helpful.
  7. K13
    K13
    X2 Gilgonzales (sp?) seems to be a super guy you might want to pm him. I know I have seen guys use multi layers of different density so you have firm on the bottom for support but then a layer of softer stuff on top so it's not so firm that it is uncomfortable.
  8. scootermcrad
    scootermcrad
    Yeah, I'm part of the group and searched first and didn't see what I was looking for, but figured I would post on the main board first in case anyone else might be interested and I thought it would be seen here first as well.
  9. All kinds of seat foam is available on ebay.
    Murph
  10. scootermcrad
    scootermcrad
    Yeah, been seeing tons on there, but just not sure exactly which one is the CORRECT one. Found some great deals on the rest of the materials needed, including the sew foam for the side bolsters. Just concerned mostly about the base foam since it will take the most abuse.
  11. K13
    K13
    The other thing you might do is go talk to someone at a local upholstery shop/furniture manufacturer. It might cost a couple of bucks more to buy from compared to the internet them but they will have samples for you to feel and sit on and be able to help you make the right choice for the density needed.
  12. scootermcrad
    scootermcrad
    Fully agree! There are quite a few places local that I can go to and definitely plan to before commiting to anything. I'm not sure if it will be cheaper per say, but educational for sure!
  13. scootermcrad
    scootermcrad
    BTTT...
    So is the green foam Polyurethane foam??
  14. ken1939
    ken1939
    Thanks for the post Tman, this is where I get my material from. Reasonable. I tend to get foam from the forementioned Joann Fabrics or similar stores. I am not sure if the green is polyu or not. I always knew it as green foam.
  15. flynbrian48
    flynbrian48
    Scooter, I went to a U-pick yard and pulled the foam from a Dodge Neon. The cushions are comfortable, and aren't attatched to the seat pan AT ALL, the upholstery holds 'em on. Utility knife is the only tool needed. Since the seat pans I built are flat, and the Neon pan is contoured, they get a little uncomfortable after an hour or so, but I'm not re-doing my seats just yet. No shaping foam needed other than t******* the back to fit the curve of my seat bucket. Use an elec. knife.
    Brian
    Oh, they cost 5 bucks.
  16. REM/Mo
    REM/Mo
    from Missouri
    I'm with flynbrian on this.
    I talked to a local upholsterer about this and he said the best source for good foam was old seats.
    Lots of choices and cheap.
  17. scootermcrad
    scootermcrad
    Oh! Great! Thanks! Prices are good too!
    My chick goes to Joann's and a discount fabric place here that's got all that stuff too. I'll tag along next time and see what they have. Just figured anything they have wouldn't be appropriate for the wear and tare of automotive seats.
    Good point on the junk yard seats. Course ya' never know what's been spilled in those seats either. :eek::rolleyes:
  18. rustythumb
    rustythumb
    try a-1 foam & fabric in santa ana ,also aaa, there on main near edinger.
  19. scootermcrad
    scootermcrad
    Cool! Thanks!
  20. And report back with your findings!
    BTW, you dont have an interior shot of that black 32 from the GNRS do you? Adding reference pics to my cork board!
  21. scootermcrad
    scootermcrad
    Awww jeesh... Which one was that??
    I will report back for sure. There will be "build pics" of the seat cushion construction on the master thread at some point.
  22. texasred
    texasred
    from Houston
    If you are only having 1 1/2 for your ***, i would go with a gel pad.. nothing kill's a good ride like a numb ***...
  23. Injected smallblock with rams horns, diamond pleated interior with many flanged holes...........Floyd Williams car. Found good pictures on a thread here and lost em!
  24. scootermcrad
    scootermcrad
    It get another layer of stuffed rolls too, so a little more than that. Making it so more foam can be added if needed.
    I think I know which one you mean. If it's the one I'm thinking of, it was when I was having camera problems and the shots were terrible. Don't think I got interior pics either... Gonna have to go back and look.
  25. scootermcrad
    scootermcrad
    Quick google search gave me what you're talking about...
    (build thread here: http://www.fastlanerodshop.com/williams.htm)
    And YEP! That's the car my camera was screwed up on.
  26. Thanks, the pics I was after were on Lanes site!
  27. BigEd
    BigEd
    Here's some more info and a place to buy:
    http://www.rochfordsupply.com/buyersguide_foam.asp
    The numbering system for polyurethane foam is very simple. The first two numbers describe the quality of the foam, and the second two numbers describe the density (ILD or indent load deflection) or firmness of the foam. The higher the first two numbers are, the better the foam quality is. The higher the second two numbers are, the greater the density of the foam, and the firmer the foam is. The first two numbers should be at least 22, with really high quality foam being 30 to 35. The second two numbers are as follows. 30 to 35 is medium, 40 to 55 is firm, 65 is extra firm, and 80 is hard. Back foam doesn't need to be really firm, or of very high quality because it gets very little wear. Seat foam, on the other hand should be higher quality and the density is a personal preference. 2235 would be good for back foam, and 3045 would be fine for seat foam. You can subs***ute a lower ILD foam for a higher one by making it thicker and wider and pulling it tighter. (BTW, the color of the foam does not mean anything, the only thing that matters is the numbering system).
  28. scootermcrad
    scootermcrad
    SWEET! There we go!! THAT'S the info I need right there! Thank you BigEd!
