Seat help for my 32 coupe
Discussion in 'The Hokey Ass Message Board' started by hd1084, Feb 10, 2014.
  1. hd1084
    hd1084
    Just looking for some ideas on a good seat set up for my ride.
    I think I want to go with buckets but looking for ideas
    Any help would be appricated. Thanks
  2. T&A Flathead
    T&A Flathead
    If it's for the 32 in your avatar photo, 64/65 mustang buckets might work good.
  3. MAD 034
    MAD 034
    from Washington
    If you decide a bench is in your future an early 90's Chrysler mini van middle seat is a common used item which works well.
  4. scotti32
    scotti32
    I have used a glide seat in the past. Very comfortable.
  5. da34guy
    da34guy
    If ya go bench, here's a Caravan middle seat I just stuffed in a 3 window I'm doin.
    $25 @ the local wreckers yard
  6. Old Ford Coupe
    Old Ford Coupe
    If you go with a bench, agree with the others. The early `90's Chrysler products (Dodge, Plymouth or Chrysler) mini-van middle seat works well. I just installed one a couple weeks ago. It was out of a Plymouth Voyager. Bolted it right to the floor (no risers) due to 3.5" chopped top. Also, if yours is a Henry steel 5-window coupe, you have the shelf in the back wall to factor in. The mini-van seat will fit under the shelf (if required for leg room) if bolted right to the floor. The backs of the Mustang seat will not fit under the shelf. If yours is a steel 3-window or gl*** (either 3 or 5-window) choices are endless. A friend of mine has the Mustang buckets in his 3-window and they fit/look good and are comfortable.
  7. wingman9
    wingman9
    from left coast
    I like the seat in my coupe, but seriously, early Mustang seats work well.
  8. 33WIRE
    33WIRE
    On my friend's chopped 32- five window we used a Caravan middle seat, took the bottom brackets off and used a similar Ford van's lower mount and slide mechanism; cut off some unneeded parts and turned it around backward. The slide adjuster is now in the front and the angle is just about perfect with the stock floor.
  9. T&A Flathead
    T&A Flathead
    If I had a seat like yours , I would try to wear it out too fast.
  10. Merlin
    Merlin
    from Inman, SC
    I have the same seat in my 3 window. Only quirk I have with it is the back needs to be a bit taller IMO.
  11. charlieb66
    charlieb66
    Go with a bench seat, buckets will touch in the middle anyway. Easier to finish off the interior with a bench seat.
  12. hd1084
    hd1084
    Thanks for all the feedback. I think I'll go with the van middle seat..;)
