Sectioned my 1949 Dodge and now a chop
Discussion in 'The Hokey Ass Message Board' started by 46binder, Dec 27, 2009.
  1. 46binder
    46binder
    from Kenosha,Wi
    Heres a pic of the inside of the door. Need to do a piecut near the edge of the door, its in green marker if you can see. The widest part of the outside of the door was not the same as the inside.
  2. 46binder
    46binder
    from Kenosha,Wi
    Had some trouble trying the hammer and dolly on the fender. The seem on the fender had a peek, don't know if I hit it too hard or too much, but I got a small crack. I wound up doing some tacks on the backside, till they overlapped and was a full weld bead. Planning on grinding the surface welds and leaving it. Any suggestions?
  3. pitbovver
    pitbovver
    from glass city
    drill out the ends of the crack then back fill the weld....the hole will stop the crack from spreading
  4. 46binder
    46binder
    from Kenosha,Wi
    Braced up the car, and started cutting the roof. Decided on a 3" chop, knew I had to move the rear window forward, didn't look right just laying it down. Cut the curve in the side rear window, brought it forward. Next day off I'll do the relief cuts on the A posts, and weld them up, and move the B post to match.
  5. gearhead78
    gearhead78
    from Dallas TX
    I am really liking how this is looking.
  6. lorodz
    lorodz
    great looking profile ..
  7. resqd37Zep
    resqd37Zep
    from Nor Cal
  8. LabRat
    LabRat
    Subtle is the true art of custom .....
    Nice work !
  9. domepiece
    domepiece
  10. Rikster
    Rikster
    WOW... that is looking so good.
  11. robleticia
    robleticia
    Looks, good! Keep us posted!
  12. James D
    James D
    If there was ever a car in need of sectioning, this is it. Can´t wait to see it rolled outside.
  13. Mine is sectioned 6" and looks like this...
    rytang likes this.
  14. radio_king
    radio_king
    Looking really good!!Please post more pics when you can.
  15. hotrob32
    hotrob32
    from Bend
    Sectioned & Chopped
  16. 46binder
    46binder
    from Kenosha,Wi
    Got some more done today, lined up the A posts, cut relief cuts, welded. Started cutting the B posts and fitting those. Got the door in to see how it looks. The car really needed sectioning with those big slab doors. Can't move it out to take a good look at it for a while, got my 1946 IH K2 parked behind it along with piles of parts. Thanks for the positive replys!
  17. 46binder
    46binder
    from Kenosha,Wi
    Had some time in the garage and all I got done was the filler in the 1st gap by the C post. Its going to take a long time spotwelding this whole thing back together. I was planning on buying an autodarkening helmet, but I'm also wondering about a Meco midget and torch setup instead.
  18. wow, sectioned, chopped and a 440! how cool is this?
    yourve got a recipie for a winner here. cant wait to see more.
  19. 46binder
    46binder
    from Kenosha,Wi
    Started the p***enger side today, radius of window turned out a little better, probably have to mess with the drivers side again.
  20. 46binder
    46binder
    from Kenosha,Wi
    Got to do some more work on the rear window. Tacked in the filler pieces. Had some problems on it, factory lead on the rear corners below the windows, can't weld to lead. First picture you can see the outline of the lead. Looking good with the gaps filled in. Wish I could weld this with oxy-acetylene, would be nice to fill with lead too.
      259 KB
      246.5 KB
      242 KB
      230.2 KB
    rytang likes this.
  21. big creep
    big creep
    man this is looking great!
  22. Stefan T
    Stefan T
    from Sweden
    Great work keep on
  23. blt2go
    blt2go
    not that you need to hear this anymore, but your car is looking really good. doing it yourself is what it is all about, and you are kicking its ****. great job.
  24. Your taking on 2 of the hardest jobs on kustoms & making them look easy. The hard work is between pics. Lookin great, can't wait for more updates.
  25. fitzee
    fitzee
    I always enjoy a nice chop. great work
  26. 46binder
    46binder
    from Kenosha,Wi
    Started on the trunk, still have to finish welding it and tweaking the seams, its just set on the hinges not adjusted, just to make sure I cut off the right amount and right place. Just ordered a Miller auto darkening helmet today, should help with neck pain from constantly flipping down the helmet!
      254.3 KB
      260.3 KB
      245.2 KB
  27. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Nice work !! Looks great. Check out ny Thunderturd. It's a 1949 Ford four door. It's been channeled 4", chopped 4" and shortened 14".
    rytang likes this.
  28. Can you post more pics of this please!!!!
  29. LOW LID DUDE
    LOW LID DUDE
    from Colorado
    Save the drip rails when ya chop it,looks much better.The b piller is already slanted, cool.I like the 2 inch section and the way you relieved the door skin, slid down and trimmed off the bottom.Nice job. The mild section job is a lot of work but well worth it when finished.It is a suttle overall change that will give it THE LOOK! Your going to turn a lot of heads when ya drive by.
  30. 46binder
    46binder
    from Kenosha,Wi
    Started on the rear fender, learned alot on this, took my time and really paid attention to hammer and dollying of the welds. Just got some spots done to start, but I could tell how the metal shrinks around the weld, and got it flat again. It was important on this because it was caved in near the top, turned out pretty good. Huge difference with my new auto-darkening helmet. Only one bolt is holding the fender on, but I get the idea of wheel clearance. Definately going the C-notch, and seriously thinking of notching the front suspension too. The engines not going to bring it down enough, and dropped spindles for a dakota are around $350, frames already been cut up, whats alittle more?
      257.9 KB
      260.1 KB
