Technical Securing wires to steering column ?
Discussion in 'The Hokey Ass Message Board' started by Blue One, Jun 9, 2019.
  1. Blue One
    Blue One
    from Alberta
    Like the ***le says, any ideas for securing wiring from a signal switch to a 1 1/2” tubular column?
    There’s no room for anything that penetrates the column like screws or the like because the steering shaft doesn’t allow it.
    No clearance.
    I don’t really want to just zip tie it :confused::D
  2. squirrel
  3. 41rodderz
    41rodderz
    from Oregon
  4. HOTRODPRIMER
    HOTRODPRIMER
    Tie wraps?
    You might take a cue from the 54 Fords, there is a small U channel which could be easy to fabricate that runs down the outside of the column, you could make a cou[e of small taps to screw it to the column our use the tie wraps at the top and bottom to hold it in place, great way to hid the wires. HRP
  5. olscrounger
    olscrounger
    made a channel by cutting 1/2 tubing in half lengthways for the wire and securing under column with small screws.. Had to make a small notch in drop for wire to go thru-looked fine when painted to match
    Mr48chev and Blue One like this.
  6. 29moonshine
    29moonshine
    peal and stick wiring channel from lowes stick it to column then paint it to match
    dana barlow and Just Gary like this.
  7. goldmountain
    goldmountain
  8. I'm thinking either making a clip about 1/2" wide that goes around 3/4 of the column with a bump in it the same size as your loom (and slightly bent out tabs to unhook it). Your wires in a flat loom and install the clip (one at top of column and one near bottom).
    Or
    A tube on top of the column (like a shift tube on a column shift) that starts at the steering collar, ends at the column drop and the wires go inside.
    Hnstray likes this.
  9. If you really don't want to make something then you could use a registration holder with the spring.
    Mr48chev likes this.
  10. southcross2631
    southcross2631
    I second the Velcro tape . I have used it to attach plastic flat loom to a column.
  11. Blue One
    Blue One
    from Alberta
    I like the peel and stick wire channel idea and I’m going to look at the Velcro too.
    I’ve seen pre cut reusable Velcro tie wraps that would probably work.
  12. 52HardTop
    52HardTop
    The 50s Chevys used a small spring that wrapped around the column and held the wire cover in place. The Signal switches for these cars was usually an add on accessory so the spring was also an after market solution to exposed wires on the column.
    Chebby belair likes this.
  13. Something like this:
    Chebby belair and Blue One like this.
  14. Mr48chev
    LOL we show our age when we mention registration holders held on with springs. That would work though.
  15. 41rodderz
    41rodderz
    from Oregon
    So you won't even give my idea a smidge of a chance ?:(
  16. The inner shaft is that close to the outer tube?
    There’s usually at least 3/8 of air in there
  17. tb33anda3rd
    tb33anda3rd
    I have had a watch holding the wires on my truck for the last 25 years......... DSCF4055.JPG
    vtx1800, Blues4U, fordflambe and 3 others like this.
  18. Blue One
    Blue One
    from Alberta
    That’s about it. Not a lot of room.
    Not much to work with.
  19. Blue One
    Blue One
    from Alberta
    Not a chance , my name isn’t Red Green :D
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sheet metal screw I understand. Ever think machine screw's? They can be cut to be flush to the interior wall of steering tube.
  21. 41rodderz
    41rodderz
    from Oregon
    :D
  22. 41rodderz
    41rodderz
    from Oregon
    A very timely fix .:)
    Just Gary and tb33anda3rd like this.
  23. Automotive Stud
    Automotive Stud
    Agreed, its a factory problem with a factory solution. Different years and body styles, often pickups, had different lengths.
    Blue One likes this.
  24. Jokester
    Jokester
    Large (1 3/4) diameter split loom. Or get an old vacuum cleaner hose and split it open. Secure it with black thread or string.
    .bjb
  25. Doublepumper
    Doublepumper
    from WA-OR, USA
  26. Blue One
    Blue One
    from Alberta
    I have a plan. It’s going to involve a little bit of fabrication and dis***embly to install some 8x32 really shallow rivnuts (for short machine screws) that I located.
  27. Blue One
    Blue One
    from Alberta
    Well mission accomplished.
    It was only a short distance from my Limeworks signal switch to the column drop however I wanted to have the wires covered and out of sight until they could go up behind the dash, tucked up behind the column drop.
    I found some short 8x32 rivnuts which I installed and then tacked in place with the Tig.
    After that I fabricated a little cover using some 3/4” conduit sliced down and went from there.
    It’s secured by 8x32 x 3/8” stainless machine screws.
    Should be nice and clean :cool:
    71AADFA4-D71F-4FDD-B786-28278AC7E0F9.jpeg 141DDB7C-26C1-450F-A532-A686D9B40108.jpeg 64CB6352-A09D-4A93-8501-0C6D6F077141.jpeg
  28. Canuck
    Canuck
    Looks good, a nice clean, professional solution. Paint the screw heads!
  29. Black_Sheep
    Black_Sheep
    This cover was pirated from a ‘60’s Dodge. The screws are trimmed slightly longer than the wall thickness of the outer column tube. If drilling and tapping isn’t an option I would use 2 sided tape, it has less material thickness than Velcro and would look a little cleaner. image.jpg
    1-SHOT likes this.
  30. Blue One
    Blue One
    from Alberta
    No paint, it doesn’t stick to polished stainless anyway :D
