Sedan with a Keg
Discussion in 'The Hokey Ass Message Board' started by mink, Feb 9, 2009.
  1. mink
    mink
    from CT
    Anyone use a full size keg in the back of their 30's sedan?? From what I have seen it only trucks using them in the back of the bed. Well how about slim 1/4 kegs?? Any pictures
  2. Shifty Shifterton
    Shifty Shifterton
    Styling-wise, the only way to pull off a keg inside your car is to put a VCR next to it showing a constant loop of "take this job & shove it". At that point the who-shot-JR vibe will start getting so heavy the keg becomes part of the motif.
  3. 49ratfink
    49ratfink
    if I had a 30's sedan I'd put a seat back there.
  4. gnichols
    gnichols
    from Tampa, FL
    And a no smoking sign? Really, bud, a bad idea having the gas in the pax compartment. Gary
  5. mink
    mink
    from CT
    Im not talking about in the car. I think a slim quart keg might fit under the body in the rear
  6. stude_trucks
    stude_trucks
    You need a full size keg? How far you going? I usually only need a 6 pack or a case at worst for any of my trips?
  7. BISHOP
    BISHOP
    The ride hight is perfect for a full size keg, or a 55 gallon drum.
  8. mink
    mink
    from CT
    Still unsafe? Bishop how about a smaller steel oil drum
  9. 49ratfink
    49ratfink
    well if you are going to put a keg back there don't forget the giant ice bucket.
  10. Shifty Shifterton
    Shifty Shifterton
    How bout anything you put back there is just gonna end up looking like a saggy diaper with a big steamy load because of the fit between the body & frame. And the fact it's all presented at eye level.
    Seriously man, cut the frame and trim the body til it fits right, then you'll have enough covering the edges to use a tank behind the axle
  11. mink
    mink
    from CT
    even a slim 1/4 keg??
  12. Shifty Shifterton
    Shifty Shifterton
    Visualization isn't your thing, is it?
    Good luck with the project, I know from past posts you've worked real hard to get there without much real-world help. You're on the wrong track with this idea, just the honest opinion of me and apparently everyone else.
  13. mink
    mink
    from CT
  14. fur biscuit
    fur biscuit
    a nice quarter drum, with the steel rolling straps on heat shrunk to the sides. provides additional support when the air bags blow out.
  15. Harrison
    Harrison
    Sit down for this one. It's going to floor you.
    Why not just run a stock fuel tank?
    Holy ****. Sometimes I amaze myself. I'm worn out now. Gotta go lay down....
    JH
  16. mink
    mink
    from CT
    Tehe he he now you guys are just a bunch of joksters...
  17. curbspeed
    curbspeed
    There are too many hillbilly hotrods already on the road. You must be looking at Rebel Rodz magazines. Take your time. Save money. Learn proper building and design skills then start your project. Buy the RIGHT parts after you get the money to do the job right. Then you won't have people shaking their head every time they look at your pride and joy and saying "What in the hell was this guy thinking?" Hope this isn't too rough for you but you asked for opinions and your getting them.
  18. Harrison
    Harrison
    Seriously man, it looks like you have a pretty nice car going there. Don't booger it up with a bunch of "shock rod" accessories.
    I'd find a stock tank & run it if possible.
    Keep us posted.
    JH
  19. mink
    mink
    from CT
    If i was loaded as you i would , but im on a budget and thought maybe i could do something differently yet safe . But instead i let you guy **** on me some more.
  20. fur biscuit
    fur biscuit
    and you just don't get it :)
  21. Harrison
    Harrison
    I'm flat broke man.
    That has nothing to do with the fact that an ad in the cl***ifieds here & $100 would probably turn up a tank that was salvageable though.
    Hell, I'll place the ad for you. Just give me the word.
    JH
  22. flynbrian48
    flynbrian48
    I had a beautiful stainless steel tank made for my car, to fit between the frame rails. It wasn't expensive, doesn't look like an afterthought, and nobody makes fun of my mullet now...
  23. mink
    mink
    from CT
    Cutting the ****. How does the stock tank fit in there. This would be a first build obvoiusly. Do i have to run a a stock tank, what else works
  24. Sutton
    Sutton
    from BTR
    Being broke is no excuse for bad taste.
  25. Shifty Shifterton
    Shifty Shifterton
    For what most kegs are worth deposit-wise, you can buy a tank liner kit and make your own out of reasonably rigid sheetmetal. The liner will help make up for pinholed welds.
    Now the sky's the limit for tank size & placement.
  26. Mazooma1
    Mazooma1
    How about a ****load of Gerry cans....
  27. flynbrian48
    flynbrian48
    Seriously, a beer keg is the last thing in the world to use for a gas tank, unless you're building something that looks like Peterbuilt tractor. You can get a Model T style tank, oval, round, nice beads rolled in, ready to go, for a couple hundred bucks. Speedway sells spun aluminum tanks in a variety of sizes if you have to have a round alum. tank. You can scour ebay for a used tank, or the cl***ifieds here, and come up with one. You have plenty of room under that :)eek:) for a tank behind the axle, or a Duece tank out back. Lots cl***ier ways than a keg inside, which would be pretty cheesy. Sorry, it's just odd. You asked for opinions...
  28. Harrison
    Harrison
    What is that car? '32 Chevy?
    I don't know exactly how it fits but I do know that a stock tank fits. Unless you've done something crazy with the suspension, a stock tank is probably your best bet........or as flynbrian48 recommended, make one that fits the space you have.
    If you're set on something other than stock, perhaps something here would fit: http://www.thehotrodcompany.com/shopnow/show_dept.asp?dept_id=78
    JH
  29. mink
    mink
    from CT
    Ya its a 32. Wander the original tank was held in by st****s?? If i found one with a rusted inside surface should i let it p***???
  30. Harrison
    Harrison
    There have been posts here on cleaning an old tank out (using various mixtures of toxic ****) & sealing it for future use.
    I typically use muratic acid & follow with a good tank sealer. If the tank isn't rusted though (& some will argue that even if it is) it can ususally be saved.
    JH
