Self canceling turn signals....question?????
Discussion in 'The Hokey Ass Message Board' started by BBobb, Oct 26, 2008.
  1. BBobb
    BBobb
    Last night i got pulled over on got my ass reemed out by one of the local cops here in town for leaving my blinker on and not turning.I have an old Allstate turn signal set up on the column of my model a at this time.So my question is.... is there a self canceling turn signal out there that would work on my 47 column that is similar to the one i have
    Upfront Thanks
  2. v8 Bake
    v8 Bake
    my 49 chevy pickup has one wiyh a little wheel in it that runs on the wheel and shuts them off when you turn it.Dont know the brand but it is old add on.
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    Look for one that has a little rubber wheel on it. The wheel contacts the steeringwheel hub when the signals are on and straighening the wheel out turns then off. Or put a BRIGHT pilot light somewhere near your normal line of vision to remind you.
  4. BBobb
    BBobb
    Good to know it is an option out there.Maybe i will get lucky and someone here will shoot me a name brand
    thanks
  5. Midnight 50
    Midnight 50
    Just as a completely left field option, you could put a timed relay on your turns and just bump the turn signal and move it right back to off and have it stay on for a preset amount of time like 30 seconds. The relay will feed the flasher and then cut off.
    I know it is a left field option, but you'll never get pull over for leaving it on again.
  6. tommy
    tommy
    I'm going to add a small indicator light in the header panel above the W/S so that it is at eye level and very hard to miss because I love my art deco signal selector. I've heard of others that have added a 12V buzzer to keep you aware that it is still blinking.
  7. oldchevyseller
    oldchevyseller
    from mankato mn
    pm sent
  8. temper_mental
    temper_mental
    from Texas
    Barney must of been having a slow night .On my other ride I went down to radio shack and bought two small 12 volt lights hid them under the dash if I forgot and left a signal on it would blink blink blink until I shut it of.My 2 cents
  9. BBobb
    BBobb
    do you have any ideal who sells the flasher
  10. Steve-Cook
    Steve-Cook
    from Garner, NC
  11. koolandnogang
    koolandnogang
    from oc socal
    The orig one on my truck was made by Cabco model 434. Google didn't come up with much but you might have better luck.
  12. bcfordman
    bcfordman
    from cortez co
    the last turn signal assy I needed I used a self canceling/timed unit from watson street rod works ,hide it under the dash and keep the column clean, may not be the look your going for but it's an option
  13. acerods
    acerods
    from CALIF.
    I see the old self cancelling styles with the rubber wheel on ebay now and then. Wiring can be a bitch.
  14. 54GMC
    54GMC
    from NY
    The one out of my Willys Wagon and the Jeepster are " Sparton" I have seen them advertised at Kieser Willys in SC
  15. oldchevyseller
    oldchevyseller
    from mankato mn
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Wow slow night i guess..I wonder how many Old ladies that were going around the world in left hand turns, he had to fly by to get to you?
    I would have been tempted to tell him..hey do you realize this car didnt even come with signals when it was new..I added them in the interest of being a responsible motorist.sorry i left it on. than i would have went home and took them all off and used my hand from than on...self canceling too BTW.
    sorry got off on a rant..
  17. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Leave your arm out the window all damn night, see if the fuzz give you any crap!
    Seriously, indicator lights on the dash are the best, or a buzzer/chime. Easy and cheap!
  18. duste01
    duste01
    If your real into creating, you might find that a steering column is theoretically the same as any other. What you may want to consider doing is to take your steering wheel off, take the plate at the top of the outer tube off, or modify it to accommodate a 53- 55 ford f100 turn signal switch. They are simple, sturdy, all steel/ no plastic and not a clamp on. I dont know why people arent doing this already. It works. You will have to put a canceling catch on the steering shaft but its a good deal.
    Here is a link to LMC item 45 for 70 bucks
    http://www.lmctruck.com/icatalog/fa/full.aspx?Page=77
    You cant see anything but the signal arm coming from the back side of the column. Shoot, you might even be able to modify the collar of the column you have. Make your own lever though, they cost too much for what they are. Its an easy one to fab. Good luck
  19. gnichols
    gnichols
    from Tampa, FL
    Most motorcycles have self-cancelling signals. One "push" on the switch in either direction activates the signals and the system then cancels automatically. If you could rig a self-centering turn signal stalk on the column to momentarily trigger the bike system, it should be the deal trip and forget system. Worth a look? Gary
  20. Frosty2
    Frosty2
    from Hambone,IN
    Not to complain about a accidental turn signal being left on too much.But those of us that ride motorcycles,this can be deadly.Say I'm coming at you with my left turnsignal on and see yours on also.I assume that your turning left,but you aren't.Next thing I know your pissed off at me for turning in front of you.I would complain to my fellow riders out there that I see more bikes than cars riding with the left blinker on also.Good way to kill yourself.Thanks,Frosty
  21. duste01
    duste01
    from an electrical standpoint, a flasher is a flasher give or take alittle. you can buy one at any autoparts store and or truck stop for that matter. all it does is heat up, break contact, cool down, make contact. click-click click-click
  22. Kent
    Kent
    from KCMO
    whatda ya mean, by the time I get my car completely road ready I plan to drive around with the left turn signal on all the time........
  23. BBobb
    BBobb
    I have been riding for 27 years i currently own 4 bikes at this time and i understand what you are saying. The cop is not the only reason i am on the hunt here.I also have safety concerns also
  24. bloodyjack
    bloodyjack
    I am programing my own push button self canceling turn signals with this development board
  25. Shifty Shifterton
    Shifty Shifterton
    Have you tried a loud flasher? They seriously make them, the flasher itself makes noise. Some just have an extra loud click, others will actually beep or chirp.
  26. butch27
    butch27
    Bloody: That looks awful damn complicated for just turn signals. I adapted a Corvair unit with self- canceling for next to nothing.
  27. Gary DeVore
    Gary DeVore
    I have a Model T with "stock" type steering wheel & "stock" type column. I have the Speedway self canceling switch hooked up to the spark control with two monitary switches. Works good I have an old park light under the dash with idiot lights including turn signal lights (led's) otherwise, my dash is stock Model T with a oval Model A speedometer.
  28. Aviator
    Aviator
    You can purchase a buzzer from Ron Francis and wire it. It is loud and offensive. It will drive you crazy. You will never fail to turn the signal off. You may also do something similar with a buzzer or door bell unit from Radio Shack. It works.
  29. bloodyjack
    bloodyjack
    I want timed push buttons so they can be hidden in my 27 roadster. I am also going to monitor the brake switch to keep them flashing while the brake is pressed. Speedway sells a 100 dollar unit to do this but this is cheeper and I enjoy. Coding
  30. Mopar34
    Mopar34
    I don't need no stinkin' self canceling turn signals or warning light....I got a wife who yells in my fucking right ear to remind me when they are on.:eek::D:D
