Self etching primer
Discussion in 'The Hokey Ass Message Board' started by bobby dublin, Oct 3, 2009.
  1. bobby dublin
    bobby dublin
    from louisiana
    This has probably come up before, but I'm kinda new to this site. Can anyone suggest a good self etching primer to use on my current project (63 nova wagon)? There are alot of them out them and just wanted to know what the best was.
  2. walrus
    walrus
    Try eastwood website , they have excellent etching primers,,,,,,
  3. da34guy
    da34guy
  4. tnrotter
    tnrotter
    from Tennessee
    I've used Transtar self etching primer with a 2K topcoat for years with great success. I purchase it from a mobile body shop supply guy. Check with a local body shop and ask about such a person in your area. These guys usually carry primers, sealers, body filler, sandpaper, masking paper, etc for alot cheaper than you can go into a autobody paint store and purchase them. tnrotter
  5. pimpin paint
    pimpin paint
    from so cal
    Hey,
    What are you going to top coat your primer with? Not all self etching primers as a good match for all top coats! Also, not all self etching primers can be used over or under plastic filler repairs. Be sure to select a product that is fully compatable with all other products used on your paint job. Your local paint supply "should '' be able to supply you with the answers based on what is available in your area.
    S****y Devil C.C.
    " Hypocrisy is the Vaseline of social *********** ''
  6. Jalopy Joker
    Jalopy Joker
    welcome to site. kinda new?? first post! next time before starting a new thread do a search here on subject that you are looking for info on. then after reading existing posts start a new thread. yes, reading existing posts can take time, but you need to do your part too.
  7. inliner54
    inliner54
    PPG or Dupont both have good ones but make sure to read the tech sheets on their websites to make sure they will work for you
  8. 53 Chevyply
    53 Chevyply
    Ppg dp40...........
  9. bbc 1957 gasser
    bbc 1957 gasser
    duponts variprime acid etching ..
  10. Zookeeper
    Zookeeper
    He stole my answer. I would never use company A's primer, company B's base, and follow it up with someone else's clear. Before you strip the car, find a paint system that you (or your painter) like and proceed from there. For instance, lots of painters beleive in self-etch primers, but House of Kolor only recommends their epoxy, shot directly over bare metal and/or fibergl***. Kosmoski beleives that anything between the epoxy and metal is just asking for trouble. However that is not etched in granite if you use another brand of material. Maybe you like PPG, or DuPont or something else, and they may suggest something else. Also, many times, I have had the paint store counter guy tell me something that directly contradicts what the manufacturer says. In that case, go with the manufacturer every time. Counter jockeys are not chemists or engineers, regardless of what they say.
  11. Chaoticcustoms
    Chaoticcustoms
    Never liked etch. Id go with the epoxy..
  12. krooser
    krooser
    "best" is pretty subjective.
    I think the operator makes as much difference in the final product as the product itself.
    I use Kirker paint from www.smartshoppersinc.com ... but I'm far from being a professional.
  13. Nefarious Art
    Nefarious Art
    from Auburn, Ca
    duplicolor. just kidding don't listen to me.
  14. mikhett
    mikhett
    from jackson nj
    OLD TECHNOLOGY! Go with an epoxy primer. I use HOK KP2cf or SPI white epoxy.Most body fillers dont like the acid in the etch.
  15. lippy
    lippy
    from Ks
    I think it's DP 90 now. Don't have to wait 30 min for activator anymore. :D
  16. zman
    zman
    from Garner, NC
    They're just different colors.
  17. SlowandLow63
    SlowandLow63
    from Central NJ
    And not a self-etch either...
  18. zman
    zman
    from Garner, NC
    well that too... :p
  19. SlowandLow63
    SlowandLow63
    from Central NJ
    Plus it costs like $300! :D :D
  20. Zookeeper
    Zookeeper
    $300?? Jeez, you can get a whole car painted for that much, cantcha??
  21. DeucePhaeton
    DeucePhaeton
    I'm not a painter but have been to a few seminars and have a friend that is a sales rep. Everybody recommends using the same brand of paints from top to bottom. Mixing brands is the number one reason for failure.
  22. philly the greek
    philly the greek
    from so . cal.
    Try Valspar ,Direct to Metal. Two part mix , that goes on easy with little shrinkage and is easy to sand . I've used it for several years , with no problems. good luck
  23. inliner54
    inliner54
    yes you can with a mix of tractor paint and over reduced 15 year old acrylic enamel it will be show quality.;)
