SEMAPHORES?? Who has wired them?
Discussion in 'The Hokey Ass Message Board' started by KIRK!, Sep 27, 2007.
  1. Neophyte
    Neophyte
    These are also called "Trafficators". I recently got a 12V set off E-Bay that came from a 50's Morris Minor.
    They wire up real easy. The unit's ch***is when mounted is connected to ground. The wire coming out of it goes to positive via a switch. Note that you can't wire them into your standard turn signal circuit as that will cause them to open and close the whole time which I can't think is very good for them. They need a steady power source.
    I'm going to use it on my '34 Chevy as front turn signals. I'll be mounting them in the sides of the grille shell. I will however make a small modification and connect the bulb to the flasher circuit to allow it to flash when open.
    Here they are in action:
    http://www.youtube.com/watch?v=zkA_9TnIIeo
    I'll be using a wiring setup similar to this one. Just connect them to the turn signal switch shown.
    Closed:
    Nearly open. Note it doesn't light up until fully open:
    Open:
  2. KIRK!
    KIRK!
    That's a huge help. Thanks!
  3. Neophyte
    Neophyte
    You're welcome. It's always a pleasure to share!
