Sending unit for a '63 Valiant Station Wagon
Discussion in 'The Hokey Ass Message Board' started by JazzyAppleSeed, Jan 5, 2010.
  1. JazzyAppleSeed
    JazzyAppleSeed
    I've been searching for a new sending unit for my '63 Valiant and found two options.
    Option 1:http://http://www.classiccarautoparts.com/gastank_sending_units.html
    It says there are two lines. What is the second line for? (Can you tell I'm a novice?) :)
    Option 2 is another sending unit that has 1 line....
    Any insight is greatly appreciated!
  2. 73RR
    73RR
    Welcome to the Hamb...uuhhh...what is the sending unit for, exactly??
  3. yamadafacka
    yamadafacka
    fuel sending unit for a '63 Valiant Station Wagon... slant 6
  4. yamadafacka
    yamadafacka
    get the 5/16 babe
  5. bukibkr
    bukibkr
    Would it be safe to guess that this is the Fuel Gauge sending unit, that goes in the tank?
  6. JazzyAppleSeed
    JazzyAppleSeed
    Will do. Goodbye crappy sediment and not being able to tell how much gas is in the tank.
  7. JazzyAppleSeed
    JazzyAppleSeed
    Yes, fuel gauge.
  8. 73RR
    73RR
    Have you tried WildCat Auto Wrecking out in Sandy?? 503.668.7786
    ...and I agree with 440roadrunner on the return line...
  9. stationWAGONS
    stationWAGONS
    from Vegas
    Hey I have the same question...for a 1964.
    I had not even done a Google search yet, but I new there might not be a new one made...obsure model of wagon. Hoep there is...
    WIll look, but that link you gave in the beginning...no such company.
    And I removed the, "...ing units", of course.
    www.classiccarautopart.com Nope.
    Where'd you find one on a site that doen't even come up?
  10. stationWAGONS
    stationWAGONS
    from Vegas
    1964 valiant wagon...
  11. jrstockwagon
    jrstockwagon
    hey guys, i got my sending unit from laysons restorations. i went with the 3/8" sending unit in case i ever go with a big block. i also have a new gas tank and all new fuel line from the tank to the carb. and my gauge works intermittently. there is a fix for that though. what happens is the voltage limiter for the gauges (which is located in the fuel gauge on these early a-bodies) go out. there is a company that sells a solid state voltage limiter that will fix the problem. they show you how to get rid of your old one and wire up theirs.
    here is their link:
    http://rt-eng.com/mediawiki/index.php/RTE_ABlimiter
    or you can do this:
    http://www.slantsix.org/articles/instrument-reg/instrument_reg.htm
    hope this helps.
  12. jrstockwagon
    jrstockwagon
  13. ryno
    ryno
    single units are usually for non ac cars, and yes they are a return or bypass type vent.
  14. stationWAGONS
    stationWAGONS
    from Vegas
  15. moparforlife
    moparforlife
    from Rolla, MO
