Technical ***September 2023 Banger Meet Thread - Beginning the Ber Months***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 31, 2023.
  1. winduptoy
    winduptoy
    Oh, I am sorry that this is the case....CDO and I have been into ours to correct the result of lean cylinder problems. Please keep us appraised of your findings... at least the bang didn't result in a lock up of things that rotate
    I've only seen a couple, but there was a Ford cast exhaust manifold that exited out the front. I believe that it was a stationary engine exhaust. That would be a find to address the heat on the floor...
    Good luck
  2. Star 351
    Star 351
  3. Star 351
    Star 351
    That would be interesting to see but packaging exhaust on a right hand drive model a is difficult, will update after more dis***embly 20230913_154015.jpg
    winduptoy likes this.
  4. Crazydaddyo
    Crazydaddyo
    What oil pump are you running?
    Pressure relief valve on oil pump? What is the relief pressure?
    Were you using the stock spring loaded cam ****on?
    Did the cam gear come loose?
    Are you running an oil pressure gage? If so what was the oil pressure when the engine washed out the cam gear?
  5. Star 351
    Star 351
    Stipe pump and relief, engine had consistent 40psi, oil pressure was still at 40psi when the engine coughed but after that had zero, turning the oil pump with a screwdriver the pump moves nice and smoothly
  6. 4bangerbob
    4bangerbob
    from AB, Canada
    Did your block have the hole for the oil port leading to the face of the cam gear drilled. (see attached picture). The first run of blocks did not have that feature.
    Also was the aluminum cam gear a cast unit or was it made from forged billet (6061 T6) aluminum?
  7. Outback
    Outback
    from NE Vic
  8. Star 351
    Star 351
    Between y*** and Gundagai
    Outback likes this.
  9. Outback
    Outback
    from NE Vic
    A long way to go home from there.
  10. choptop4
    choptop4
    Our Riley 2 port. Had it over 40 years.
  11. Star 351
    Star 351
    Yes the block did have the oil hole, not sure if it's a billet or cast gear
  12. Star 351
    Star 351
    We got the burtz fully dissembled and we discovered the culprit, when we built the engine we used a cast crank gear amd that failed taking out the aluminium timing gear with it, at the time it was all that was available in Australia as shipping from the USA to Australia basically stopped during covid when we were building the engine, everything else in the engine looked great 20230923_170108.jpg
  13. wuga
    wuga
    Thom goes into far greater detail on the Facebook forum The Burtz Ford Model A Engine. with multiple pictures.
    In continuing on from my previous post Phillip McNally and myself have spent today tearing mums burtz engine apart after a cam gear failure, we weren't surprised by the condition of everything other than the timing gears everything else is in fantastic condition and shows no signs of being stressed by running down the highway at 70mph, to answer some questions, the timing gear hadn't come loose or out of adjustment, all the bolts were still fitted and tight and the the gear was still set where we left it when the cam was degreed in, the oil pump was free and had no scoring, the cam and valvetrain turns smoothly and appears to be in great shape, there was no evidence of the cam floating forward even though the engine has a stock sprung thrust ****on, the crank and rods as well as bearings are in fantastic shape with normal amounts of wear, there's no significant scuffing on the pistons or the bores, down to the root cause of the problem, it appears to be our fault upon inspection the crank gear is made of cast iron and was the cause of the failure, it let go and tore up the cam gear at the same time, at the time of ***embly we were unaware of the potential problems a cast iron crank gear could cause, also it was all that was available to us during here in Aus during covid, after some cleaning and ordering of parts we will re ***emble the engine and put it back in the sport coupe in the not too distant future
    A further comment was made:
    Dan MacEachern makes the finest timing gears ln the country. His heat treated steel crank gear should always be used.
    It has been encouraged to forward this info to Burtz and other suppliers.
    Warren
    Outback, winduptoy and johnneilson like this.
  14. Dan from Oakland
    Dan from Oakland
    My 1st question would be how much backlash did you have between the cam and crank gear when you ***embled the motor? Lack of backlash is the #1 reason, in my opinion for this type of failure. My 2nd question would be how was the cam/ cam gear prevented from rotating when the cam gear nut was tightened and how tight was it tightened.
    Sorry to hear of your problems, as none of us want to see this happen.
    4BangerDean, winduptoy and Outback like this.
  15. 29 Speedster
    29 Speedster
    from Colorado
    We used the MacEachern Bronze Timing Gear and Steel Crankshaft Gear when we build our Burtz engine (#0059) in April 2021. The backlash was checked every 90 degrees of the timing gear and each measurement was .004”. At testament to the gears and the alignment of the crankshaft and cam journeys. We ran the 2021 Great Race with this engine after a ~1,000 break-in, and never had any problems. The Great Race was over 3,500 miles, a lot of hard acceleration along with stop and go maneuvers throughout the event. The engine has ran fine for over 15,000 miles since then, and still going strong.
    Crazydaddyo, Outback and G Baese like this.
  16. Jiminy
    Jiminy
  17. V4F
    V4F
    from middle ca.
    november ??
  18. Jiminy
    Jiminy
    The November Meet was announced in the October Thread
    hotrodfil and Outback like this.
