Technical ***September 2024 Banger Meet Thread - First BER Month ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Sep 2, 2024.
  1. Jiminy
    Jiminy
    Link to previous month: August 2024 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. denis4x4
    denis4x4
    from Colorado
    In 2001, I installed a T-5 in my CCPU using the Auto Restoration kit. Bought a new touring engine from Bert's with a V8 clutch. ordered a new throwout bearing something didn't look right. To make a long story short, the original kit came with a disk that protruded out an inch or so from the clutch housing. I was able to find the machined snout that extended the T-5 output shaft so that I could use a Model A clutch disc and throw out ***embly. A lot of extra work and cost to fix something that could have been done by the original manufacturer so that original A parts could be used.
    winduptoy likes this.
  3. 62pan
    62pan
    Checking in with a new project. Thirtys style three spring modified. Chevy frame, dodge axle, A engine and 26 T touring front half.
  4. out plowing
    out plowing
    Anyone recasting Winfield heads?
  5. iwanaflattie
    iwanaflattie
    Haven't done anything but drive the model T...
    It maybe time for an oil change...what's a good oil for a 32' banger??
    Also need front tires...what's an affordable brand for a 30" wheel?
    The "non-skid" are very expensive..
    Sorry if this isn't the right place to post it.
  6. Zax
    Zax
    chlsnk and winduptoy like this.
  7. jim1932
    jim1932
    Checking in. Got the exhaust on the car which fixed a lot of the popping issues. Just switched the carbs to "Winter" hopefully that fixes the hesitation. Got 4 events on the calander for the month after missing almost the whole Summer. Too many other things going on to focus on the engine swap.
  8. Stovebolt
    Stovebolt
    This tyre blew out at 60mph on the freeway about 10 days ago.
    A friend rescued me.
    Can't repair that tube.
    Upon inspecting the tyre, this was discovered.
    Tall 18" tyres are non-existent in Australia, so it looks like it's time for 16" Kelsey Hayes wires and big and littles. Not what I was wanting to do, rather I'm having to do it.
    Oh well, that's hot rodding
    Crazydaddyo, winduptoy and Outback like this.
  9. Is anyone supplying Blockleys in Australia?
    Outback likes this.
  10. The weekend after going to Rømø, I set off to Bicester Heritage for the VHRA Throttle Auto Races. Much nearer - just 120 miles or so each way. A one day short track event, with five cars at a time on the 1km kidney bean shaped track at once. Drove there, raced, drove home, no real dramas.
    Need to sort out my sump baffles though, as oil surge on the right handers dropped the pressure to zero.
  11. Outback
    Outback
    from NE Vic, Oz
    Crazydaddyo, winduptoy and hotrodfil like this.
  12. winduptoy
    winduptoy
    getting ready to drive to RPM Nationals later in the month
    Perfect place to post it and I like your T
    As for oil...I've been using the old formulation of Rotella T 15-30 but my drum is empty
    I am going to try the Walmart synthetic based on the test results that Lake Speed Jr did recently
    I suspect I'll get feedback on that statement
    jet996 likes this.
  13. Stovebolt
    Stovebolt
    @Outback
    I bought my front tyres for the 18’s from them
    And I just bought a full set of 16’s to suit my Kelsey Hayes from them - they provide fantastic service
    Outback likes this.
  14. Happy September everyone!
    For the hive mind, I've seen what looks to be a Ambler "Clutch Can". Unfortunately its the bare housing. Have any of you guys played around with them?
    Outback likes this.
  15. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Howdy neighbor!
    Paul Shinn says any synthetic 10w-30 is good to go for the A bangers. I can't imagine '32 is significantly different. If you have a real hot cam or high-tension cam springs you might want to add ZDDP, I guess.
  16. jim1932
    jim1932
    They re on the Reds-Headers web site. Not sure if they are in stock.
    winduptoy and out plowing like this.
  17. Checking in, decided to start the month off with a test cast of a B fuel pump block off.
    Getting the correct PPE is definitely at the top of my list, that and more sand!
    I went into the pour with low expectations, and was surprised with the quality.
    Hopefully I'll have more progress to show soon!
    Jeff34, jet996, winduptoy and 3 others like this.
  18. 4BangerDean
    4BangerDean
    Things were going well at the end of August. I drove the pickup about 500 miles or so, including a 150 mile round trip to the Cheatersma Car Show. Was putting a few miles on it over the Labor Day weekend and lost the head gasket. Unfortunately it got pretty hot before it became apparent. Fingers crossed it didn’t incur any damage.
    Anyways I pulled the head, found a gasket I find questionable and the steam holes not blocked. Got them plugged and will hopefully get the head back on tomorrow night. I’ll start it up see what I got.
    I hope everyone in banger land here is doing well.
  19. Savage Coupe
    Savage Coupe
    from Washington
    Destroyed 1st gear at the Estranged drags. Can we get it rebuilt and back together for RPM nationals??? IMG_6671.jpeg IMG_6757.jpeg IMG_6759.jpeg
  20. iwanaflattie
    iwanaflattie
    thank you..
    Rpm nationals!! I'm going to try to make it.
    Hey neighborino,,,thanks for the info..
    Hope to cross paths sometime.
  21. 4BangerDean
    4BangerDean
    IMG_6864.jpeg IMG_6865.jpeg Looks like a planned engine build is getting closer. A bunch of parts have arrived to start the month off including a GEM 7:1 head, Brierlry 1R Cam, Burns Dual Intake and a pair of Stromberg 81’s.
    chlsnk, Outback, 282doorUK and 2 others like this.
  22. 5280A2
    5280A2
    Be sure to fit a head gasket to that head before installing it. It looks to me like the flycuts are not symmetrical adjacent to the head bolt holes so a Model B gasket may overlap into the combustion chamber in those areas. The A head gasket is narrower in that location. If the fit is poor with an A gasket you can install the gasket with the crimp down against the block so only solid copper is exposed at the edge of the combustion chamber (***uming a copper sandwich head gasket). I have a reproduction Winfield head that suffers from somewhat inaccurate casting of the combustion chambers and this approach has worked for me to avoid damage to the crimped part of the gasket from combustion heat.
    VF-1 and jet996 like this.
  23. 4BangerDean
    4BangerDean
    I see what you are seeing. The supplied head gasket(Best 509) appears okay to me. Unfortunately this head is going to be used on a new build which is quite a few months out. I don’t know of any machine shops nearby that can or will machine for insert bearings or drill cranks for full pressure oiling. Although I know of a good flathead shop.
    I’m new to diving into these Banger equipped Early Fords but I’m hooked. I’m learning by doing and I have a long way to go. Any help, comments etc are greatly appreciated. I plan on playing with high performance bangers until I’m no longer able. I’m quite interested in them.
  24. 5280A2
    5280A2
    Thanks for showing the photo with the gasket. The GEM head is new to me; any details you can share about it?
    Outback likes this.
  25. 4BangerDean
    4BangerDean
    It’s made by Belcher Engineering in the UK. I’m not quite sure where I first saw one but I thought it looked cool and the engine it was on seemed to run well. So I bought one. My plan is to run the Dual 81 Strombergs with the Brierley 1R regrind.
    As much as I wanted to go with a Miller/Seer head It’s just not in my budget plus I think a flathead will provide me with what I’m looking for. I fully intend on using my Model B as a daily driver. I’m thinking I should start a build thread on making my B a daily driver. It’s been a bit challenging,
    5280A2, G Baese, out plowing and 2 others like this.
  26. Outback
    Outback
    from NE Vic, Oz
    I took the A for a blast today, on some local dirt roads, caught up to a 'modern' that was scared of some dust & pot holes :D
    Was a really nice way to finish the weekend.
    Went to visit a local mate who got a Tub in the shed IMG_20240908_173348305.jpg IMG_20240908_162545427.jpg
    Aside from sorting the wiring, I need to build up the p***enger side latch to stop the door opening & kids falling out , fix the gearbox to stop it jumping out of gear, & it will be much nicer to drive.
    Then soften the springs/shocks, windscreen, seat, bigger rear tyres etc etc
    Shutter Speed, VF-1, Lil'Alb and 5 others like this.
  27. wuga
    wuga
    Outback likes this.
  28. Outback
    Outback
    from NE Vic, Oz
    Thanks the latch is quite worn & needs building up, but I do agree something more 'secure' is a good idea
  29. Outback
    Outback
    from NE Vic, Oz
    & Just for a bump,
    I had the local hot rod club visit for a shed crawl on the wk end, I had a clean up & mocked this up so there was something to look at. It'll be a while off, but it will be be banger powered IMG_20240907_122233425.jpg
    GuyW, Lil'Alb, Mikko_ and 2 others like this.
  30. Stan Back
    Stan Back
    . . . ever try seat belts?
    Of course, you could fix the doors and hope that they're thrown clear.
