Technical ***September 2024 Banger Meet Thread - First BER Month ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Sep 2, 2024.
  1. Outback
    Outback
    from NE Vic, Oz
    I do have seat belts & the kids haven't fallen out the door, I guess I was having a joke about a serious situation if it ever happened.
  2. jim1932
    jim1932
    How often should you swap out gaskets on stromberg 81's? I bought mine from Uncle Max maybe 10 years ago. They have been on and off the car the last 5 years. They seem to run OK but I noticed the gaskets look wet with gas and I need to keep cleaning the carbs and intake. I don't see any leaks, just the general dampness and a seemingly adnormal odor of Gas. The screws are as tight as I dare.
  3. jim1932
    jim1932
    Sorry for the ignorance but what is the aluminum under the body?
  4. iwanaflattie
    iwanaflattie
    I'm not sure...probably for looks.
  5. jim1932
    jim1932
    Oh, I thought it was yours.
  6. iwanaflattie
    iwanaflattie
    It's mine...I bought it that way
  7. jnaki
    jnaki
    Hello,
    For any So Cal residents close by or can plan on attending the resurrected famous hill climb event, here is the latest:
    A friend just sent me a note about the old Long Beach Model T club's annual hill climb on Hill Street. The steep hill has some great history and during our visits there, watched those guys try to go up that steep hill. Some did, while others did not. There was a great old thread here on the HAMB about the last one many years ago.
    Here is the note:
    The Signal Hill Model T race will take place on Saturday, Sept. 14 2024 at 10AM at Discovery Well Park, located at 2200 Temple Ave. in Signal Hill.
    Jnaki
    The hill is still there as always, but now has a modern look. But, for those old Model T cars, it still offers a challenge. The view heading down hill going east is pretty nice, but it is Long Beach/Signal Hill area.
    So, how does a full power 348 Chevy Impala do on the same hill? well, it goes up very fast and at the top almost gets the famous "air" as it crests the hill. Sure we all like to say it gets lifted off of the slope like in the movies, but the car was too heavy, despite 300 hp at full power. Somehow, the teenagers inside sure had a heck of a time whooping it up all the way to the top... ha!
    Wait, what about the flathead powered 1940 Ford Sedan Delivery? It was well known that the flathead was underpowered. But, in first gear, shifting to 2nd and then back to first, we made it to the top, just chugging up the hill. Slow, straining and steady made the grade. surprise!
    Note:
    The weather is cooling, today, but it will still be rather warm on Saturday. Unless, of course the ocean breezes come to the rescue...
    The view from the top of Signal Hill looking east, today, would be a great view of the smoke funnels rising from the Orange County fires that have been causing all sorts of evacuations and road closures. YRMV
  8. burl
    burl
    from Minnesota
    Was a good time last weekend in Northwoods Iowa for the flat hill climb. Bills model A,#33, with the Gemsa overhead conversion was king of the hill at over 70 mph and low 8 e.t Good to see @msnevilempire with the Heap and @5280A2 with his fast RPU as well.  northwoods 6.jpg northwoods 1.jpg northwoods 3.jpg northwoods 4.jpg northwoods 5.jpg northwoods 7.jpg northwoods 8.jpg northwoods 9.jpg northwoods 11.jpg northwoods 12.jpg
    Lil'Alb, winduptoy, brjnelson and 7 others like this.
  10. Kevin Pharis
    Kevin Pharis
    from Califunny
    Early A multi disk clutch…? Pretty sure I have 4 or 5 layin around. I never came across the special transmission input shaft tho
    jet996, Retson the Racer and Outback like this.
  11. Outback
    Outback
    from NE Vic, Oz
    I just bought an early multi-plate clutch gearbox, we seem to have a few out here
    Retson the Racer likes this.
  12. hotrodA
    hotrodA
  13. Yessir! I've got a boat load of nice later A transmissions, but nothing early 28. I'm hoping to be able to find a few clutches, borrow a KR tool, and get in there to learn how to rebuild a clutchpack!
    It seems out on the West Coast here they're about rare as hens teeth! Go figure
    Thank you! Unfortunately it is just the housing, so I'll need just about a whole transmission! I've got some photos of what the Ambler branded cover looks like, so I'll be able to work towards casting one.
  14. Kevin Pharis
    Kevin Pharis
    from Califunny
    I’ll dig up what I have, doubt I’ll ever use it. Pretty sure I have a couple flywheels and a bucket full of clutches… just have to find it:oops:
  15. jim1932
    jim1932
    Displaying my HAMB topper at the Hemmings Cruisin in Bennington last night. 80 miles round trip with no incidents.
  16. 25mercury
    25mercury
    Reason, here is a multi clutch from an early 30's sprint car. The flywheel has been cut down to 8 inches and a seamless steel tube has been shrunk over it to help keep it together. The multidisc transmission has a different input shaft.
  17. Dan from Oakland
    Dan from Oakland
    Here is a few shots of the multi disc clutch setup in #40 to give an idea of why they were used in early sprint cars- Bolted to the back of the block with a motor plate in between. Pretty simple. This one has no name and a typical casting, it has been repaired and at some point..
    Outback, winduptoy and jet996 like this.
  18. I know that feeling, let me know! Thanks
    Thank you for all this! Is there anything needed to be done to adapt the multidisc trans to that can? As my lathe only has a swing of 9", I'll have to have some friends machine my flywheel once I find one!
    Outback likes this.
  19. hotrodA
    hotrodA
    Here is the setup behind the vintage sprinter engine I have. It came attached to it.
    AR trans with trick clutch linkage and pedal, cut down shifter, AR clutch with all steel discs and cutdown flywheel clutch can with timing marks.
  20. Kevin Pharis
    Kevin Pharis
    from Califunny
    Looks like my stash of early clutches and flywheels didn’t survive my dads move last year…:(
  21. I swear, this is probably one of the top 5 engines in my book. Everything about it is just so damn cool! How did the leg feel with all steel discs?
    I hate when that happens, thank you for looking anyways! Always appreciated. I'm working on a script for HAL and my next episode of 4 Banger Archives. Mind if I send it your way for some critiquing?
  22. Took the kiddos to the Early Ford show hosted by the Santa Maria Model A club, their favorite car was the Fronty speedster... go figure Screenshot 2024-09-14 at 1.52.33 PM.png
    hotrodA, GuyW, Shutter Speed and 5 others like this.
  23. Outback
    Outback
    from NE Vic, Oz
    I ***ume push start only?
    winduptoy likes this.
  24. hotrodA
    hotrodA
    Yes, as the bellhousing has a homemade aluminum plate cover over the starter hole.
  25. Kevin Pharis
    Kevin Pharis
    from Califunny
    Send it over, happy to help!
    Also, my dad sniffed out some multi disk clutch stuff on the other side of town. Let me know if yur still lookin
    Outback and Retson the Racer like this.
  26. Will do! Definitely interested, I'll send you a message right now!
  27. Deeluxe
    Deeluxe
    from island
    This Right Here is exciting!
    Outback likes this.
  28. That is so cool, thank you for the photos!! Is there any chance you could PM me a straight on photo of that Ambler cover? I scanned the Ambler can with the help of my son, and I'm going to start working on a new inspection cover to cast! Ambler.png
    Outback likes this.
  29. hotrodA
    hotrodA
    @Retson the Racer
    I’ve looked for years for an Ambler or equivalent to no avail. Either gold plated or sold instantly.
    Guess I will be content with my OE setup as it was in use at one time.
    If you decide to move yours along, let me know.
    Outback likes this.
  30. jet996
    jet996
    from WY
    IMG_3231.jpeg Pulled the axle out of my pickup to take some leaves off and reverse the main leaf eyes. I've seen some janky axles but dang...
    GuyW, Jeff34, Outback and 1 other person like this.
