set up a dropped axle
Discussion in 'The Hokey Ass Message Board' started by coolbreeze1340, Aug 2, 2010.
  1. coolbreeze1340
    coolbreeze1340
    from Indiana
    I am just putting my car on the road and need some guidance. I have a dropped Super Bell axle set up and need to hear how everyone has it set. The car seems to drive good but I think there is room for improvement. Any leads on a good tech?
  2. Hightone111
    Hightone111
    It's already built? What do you mean set, like toe/caster settings?
  3. coolbreeze1340
    coolbreeze1340
    from Indiana
    Yeah, it's already built but I would like to know how they are adjusted (toe/caster) and the other in and outs of a dropped axle. I can't believe there isn't a tech on this one yet!
  4. alchemy
    alchemy
    Details please. What kind of car, locating (4 bar, hairpin, wishbone), spring and shackles, bias or radials, etc?
  5. coolbreeze1340
    coolbreeze1340
    from Indiana
    1931 Tudor Sedan, hairpin, super bell 4" drop chrome front end (the complete kit), disc brakes all on a re-pop 32 frame with vega steering box. I run radials front and rear.
  6. modelacitizen
    modelacitizen
    Well you really can't do much about adjusting camber because that is set by the king-pins. I'd shoot for 7 degrees of caster and around 3/16 of toe...
    How is your steering setup (cross steer)? The really isn't a 'tech' for this kind of stuff because it's not a one size fits all operation. Everyone's setup is a little different. The specs I mentioned are probably a decent place to start. Beyond that, just drive it and adjust as you see fit.
  7. 1931av8
    1931av8
  8. flt-blk
    flt-blk
    from IL
    Like they said, not much you can adjust
    Caster might be adjustable if you need to
    Set toe at 3/16 and you're done.
    You never said what problem you are trying to fix.
  9. alchemy
    alchemy
    I've read somewhere that radials shouldn't have as much toe in as bias, but I can't find the actual numbers. The bias on the dropped I-beam I set up like a lot of toe-in. Probably 3/16 at least. I just kept adjusting inward til it felt right.
  10. Kramer
    Kramer
    I read that on here somewhere, but also don't remember the numbers or what thread I saw it in.
  11. Alchemy we used to set toe on radials @ 1/8".
    I don't know if anyone has any real numbers but that was what we set them at.
    7 degrees is about where you want your caster if you are going to drive it. A little more makes it a little more stable at speed but it starts to get sluggish in the steering dept.
  12. coolbreeze1340
    coolbreeze1340
    from Indiana
    Thanks for the information, I'll read some of ther posts mentioned. The car seems to drive OK and straight just feels a little loose in the rough spots. I do not have a lot of information on the frame set-up so I am more or less just back checking the work that was done by the PO.
  13. heavier cars need less caster than lighter caster is used for steering self centering and so that the car goes straight and doesn't wander also more caster you have the heavier the steering feels
