I've heard to set crossmember at 7deg back what happens if it is 10 or 12 or 15 deg back or even 3* just wondering (4inch drop axle wishbones) Posted using the Full Custom H.A.M.B. App!
the steering wheel will return faster after a corner and your front end will look like a dragster when turned
depends on the weight of the vehicle, and scrub radius. Too much + caster combined with too much scrub radius can trigger the evil death wobble.
Search function is your friend. Less caster, easier to steer, more caster harder to steer but more stable at speed. There is a happy medium in there, 7 degrees.
