Hot Rods Setting caster ?
Discussion in 'The Hokey Ass Message Board' started by Jet96, Apr 1, 2017.
  1. Jet96
    Jet96
    from WY
    IMG_3883.JPG so I've read up on caster angles and most agree that 7 degrees is about right. After much heating / beating /bending, I've got my crossmember about right but my axle doesn't line up with the transmission at all? I could use some suggestions here. Thanks
  2. RMR&C
    RMR&C
    from NW Montana
    April 1st, right?
    turboroadster and lurker mick like this.
  3. sunbeam
    sunbeam
    Are you talking about the rear axle?? Oh wait RMR&C is right.
  4. AVater
    AVater
    Looks like an Ackerman issue to me:p
    Jet96 likes this.
  5. Marty Strode
    Marty Strode
    The pinion angle might be off just a shade !
    lurker mick and Jet96 like this.
  6. roundvalley
    roundvalley
    You need to bend the transmission mount now to match.
    Jet96 and anothercarguy like this.
  7. jimmy six
    jimmy six
    I feel the rear will track perfectly but the steering maybe a little hard. I suggest an 18" steering wheel.
    Jet96 likes this.
  8. themoose
    themoose
    Adding an 18" steering wheel will require the lowering of the seat to gain clearance which will then require lowering of the floor which will result in the need to re-bend the transmission mount...Catch 22
    Jet96 likes this.
  9. Looks good to me !
    Jet96 likes this.
  10. dreracecar
    dreracecar
    from so-cal
    Stogy and Jet96 like this.
  11. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Ya know, there's at least one on every web site today! By the way, is that YOUR kid jumping up and down on your hood?
    KK
  12. It'll work...just heat up the torque tube and bend it...you may need a big piece of pipe on it...but it'll go!
    Jet96 likes this.
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    You made negative caster, should have been positive. Bend it the other way, it'll be fine.
    Jet96 likes this.
  14. woodiewagon46
    woodiewagon46
    from New York
    No need to bend the torque tube, just heat and bend the spring.
    Jet96 likes this.
  15. Larry W
    Larry W
    from kansas
    I agree , you went the wrong way.
    Jet96 likes this.
  16. Stogy
    Stogy
    That looks like it had the rear end chained to a post alignment/caster adjustment process done to it...
    Jet96 likes this.
  17. texas red dodge
    texas red dodge
    caster didn't he die and his brother take over ???????
    Jet96, Stogy and themoose like this.
  18. themoose
    themoose
    No... you must be thinking of that famous Fidel player.
    Jet96 and Stogy like this.
  19. Sheep Dip
    Sheep Dip
    from Central Ca
    Flip the body around 180...it will work then.
  20. I wanna know the story of how it got like that
  21. Jet96
    Jet96
    from WY
    Thanks for the valuable input guys! I think SheepDips's solution is probably the most do-able, HaHa.
    And yes, I would like to know the story on how it got twisted. It would take a Ton of force to roll it like that. Luckily the rest is absolutely arrow-straight, so it's going under my little roadster.
    Stogy likes this.
