setting my timing
Discussion in 'The Hokey Ass Message Board' started by 454navyss, May 18, 2010.
  1. 454navyss
    454navyss
    my car has a .040 over 350 in it, edelbrock intake, 650 street demon and a 219/224 @ .050 duration, .485"ish lift on a 112 cam, where should my timing be set at? it runs fine now just cruising but if i try to get on it, its ok for a second then falls on its face. thanks
  2. shemp
    shemp
    Alliance Vendor
    Sounds like it might need more pump shot.
  3. canman
    canman
    Yeah that's not timing. Should be about 36 degrees on a curve that has it all in by 2000 RPM (depending on fuel). Pump shot sound about right.
  4. 454navyss
    454navyss
    ok, i'll see if i cant figure it out. thank you
  5. Ace50coupe
    Ace50coupe
    from Indiana
    try about 8 to 10 degrees ATDC mine is set that way also look into your fuel pump you may need about a 110gph pump for your carb and cam. It may be fine at idle but once you put your foot into it the fuel pump may not be enough. Peak power is made right before detonation in an engine so dont get to crazy with advancing the timing though.
  6. 454navyss
    454navyss
  7. Retrorod
    Retrorod
    Vortec heads don't like quite as much timing as the earlier heads...I'd go no more than 32 degrees total with it all in by 2000 rpm on a straight centrifigal distributor. I would start at about 5 degrees initial.
  8. 454navyss
    454navyss
    i also have an hei distributor
  9. JohnEvans
    JohnEvans
    from Phoenix AZ
    You will find the more radical the cam the more inital advance is needed . As long as it does not kick back when cranking 12-14 inital will give better throttle response . 32-36 total by 2500usually works good. Light cars seem to be OK with it all in at a bit lower RPM.
  10. redlinetoys
    redlinetoys
    from Midwest
    With a decent size cam and carb, it is not unusual to need 18-20 initial timing and 36-38 full in. Would definitely adjust the squirter pump for a stronger shot first. That is a simple try and it can make a huge difference.
  11. I run a roller cam with 510 lift with Vortecs. To run over 500 lift with Vortecs you need better springs and to run better springs you have to cut the spring pockets.Once you do that-they're great but about 32 degrees total advance at 3000 rpm is all they want before they get noisy.
    Jim
  12. 454navyss
    454navyss
    good information to know. thank you guys
