Technical Setting side window glass
Discussion in 'The Hokey Ass Message Board' started by crminal, Apr 11, 2017.
  1. crminal
    crminal
    Need to install side window gl*** in my 57 Ford. New gl***, good channel and I have the special "setting tape".
    I will have to put the gl*** up into the door, then bring the track up from below and push the gl*** down into the track.
    I have heard that it works well to use mineral spirits or Stoddard solvent to soften the rubber and make it slippery for the gl*** to slide into.
    Any experience with this?
  2. okiedokie
    okiedokie
    from Ok
    In your pick up? In my 53 F100 I set the gl*** in the channel then installed. Rubber mallet used to tap the channel down onto the gl*** then trim off excess tape with sharp knife.
    belair, tb33anda3rd and crminal like this.
  3. crminal
    crminal
    Thanks OkieD. So I guess you left it dry.
    Yes, my truck
  4. 32fenderless
    32fenderless
    Just went through this on a '57 Chev project. Local gl*** guy told me he used trans fluid. Not sure if it was type F or dextron. [emoji3] I used dextron and it seemed to swell up and work good.
    crminal likes this.
  5. greg32
    greg32
    from Indiana
    Setting tape comes in different thicknesses. Use the one that holds the gl*** firmly, wet it with water, and rubber mallet it. Should be a tight fit.
  6. Chuck Craig
    Chuck Craig
    from Ocala FL
    We used lyptine? for years in the gl*** shop, but lacquer thinner will work. Put it on a rag, after you cut the special tap to the proper length and have the gl*** and lower channel ready to install. Make sure that you install the lower channel in the proper place as you do not want it to rub the front or rear vertical channel. If you did not remove it from the old gl***, I suggest a test fit before installing the setting tape, once this is done mark the proper position with a piece of tape. Put the gl*** on a piece of carpet or (???) to cushion it and stand it up, wet the tape and install the channel with a tap of a hammer or you may just be able to push it on as the thinner makes it slick. If more questions, just ask.
  7. crminal
    crminal
    Thanks
    Great advice. Definitely needed to check and recheck all clearances, up and down a few times noting positions of the lifting arm and track.
    I took the panel off the opposite door so I could check out the proper location of things.
    Only one local gl*** shop that had the tape and only one thin size available, so I had to resort to stacking layers. It does seem that the thickness is imperative. Three layers of the tape (so basically 3 on each side or 6 total) seemed just right but even with a solvent for lube, just couldn't get it in. Took one off one side ( so 5 now) and it pressed right in. Used Gibbs for lube as it is solvent based.
    Thanks everyone!
    greg32 and belair like this.
