Hot Rods Setting stock wheels inside towards the frame
Discussion in 'The Hokey Ass Message Board' started by 6inarow, Sep 13, 2025.
  1. gene-koning
    gene-koning
    How long ago did you purchase the disc brake kit? Maybe it would be worth persuading a refund through your credit card. Don't wait to find out, there is a time limit through which the credit card company has to work.
    We would also like the name of the disc brake company. I sure would not want to take a chance with their description of "the parts will work without any problems"
  2. 6inarow
    6inarow
    @gene-koning I bought the kit in June. You know how these projects go. Needs tires. Needs alignment. Had not run run in 25 years. So there were a lot of things to fix to get it on the road. Got it going about 2 weeks ago. Ill call the company tomorrow before I spill their name. Their customer service so far has ****ed. Once they got my credit card payment they have been hard to deal with. Ill give them one more chance. Im not hoping for much though
  3. gene-koning
    gene-koning
    Check with your credit card company, you may still be within the time frame.
  4. K13
    K13
    You spilled their name when you posted a picture of the kit you bought. It's right there.
    lurker mick likes this.
  5. proartguy
    proartguy
    from Sparks, NV
    I was using the wording you posted.
    No doubt there is little detail on that site about their kits. Other vendors do post the instructions for theirs online or give better specs. Whatever happened - this is where you are now - and perhaps the advice to modify the caliper brackets and spacer is the best, although not the easiest, way to fix it.
    6inarow likes this.
  6. 6inarow
    6inarow
    @proartguy no problems. All good. So I called the company today and had a discussion about if in fact they pushed the wheels out. The answer I got was in my case it was to be expected. But they offered to fix it with some modifications but for a labor fee. So I guess where it stands now is we agree it didn't work on my car. What I think I am going to do is investigate other kits and compare and see what the "best" thing for me to do is. Thanks to all who responded.
  7. pprather
    pprather
    So, you are not going to consider modifying the kit you have, as suggested by @ekimneirbo and @proartguy above?
    ekimneirbo likes this.
  8. buds56
    buds56
    In the few disc conversions I've done the tire has been moved out a bit.
    I would go down a tire size and drive it. Good Luck
    RMR&C and 6inarow like this.
  9. RMR&C
    RMR&C
    from NW Montana
    You might look for a "hat " type rotor that would fit over your OE hub. They are sometimes used on 4x4's. I went this route on an oddball axle, it kept the track width stock
    tb33anda3rd and 6inarow like this.
  10. 6inarow
    6inarow
